Major Rust Problem
Old Feb 9, 2012 | 09:44 PM
Tifferific's Avatar
Tifferific is on a distinguished road
Default Major Rust Problem
I have an '81 Jimmy and of course it has rust spots. Some are bubbled up under the paint and others actually made holes in the metal. Does anyone know how I can go about getting this rust removed?? Also I have rust on the inside of the door where the seals would be.
Attached Thumbnails Major Rust Problem-imag0350.jpg   Major Rust Problem-imag0352.jpg   Major Rust Problem-rust1.jpg
Old Feb 9, 2012 | 09:48 PM
bigkhans's Avatar
bigkhans is on a distinguished road
Pics would help, but I'd sand them down and spray on some rust converter, and then repaint if their not that bad of condition. That's if its surface rust only. As for where there are holes in the metal, cut it out and replace the metal or replace the panel all together.
Old Feb 9, 2012 | 10:37 PM
richphotos's Avatar
bigkhans said it perfect. grind it down, spray on some rust converter for the bubbled paint rust, for the holes, cut, and weld in some new sheet.
Never use bondo for holes, you will just be wasting your time.
Old Feb 13, 2012 | 10:50 AM
Tifferific's Avatar
About how much do you think it would cost to have a shop do it for me??
Old Feb 13, 2012 | 11:51 AM
bigkhans's Avatar
Shop around and get lots of estimates. Go to the most expensive shops and then to some of the cheaper shops. Also don't over look the tech schools you might find a decent deal there as well.
Old Feb 13, 2012 | 04:48 PM
richphotos's Avatar
I would check tech schools. Sometimes they will do the labor for free or super cheap so the students have something to learn on (yes, seems scary that they learn on it, but its with supervision of the instructor)
Old Mar 15, 2012 | 10:59 AM
defiantcustom's Avatar
defiantcustom is on a distinguished road
Figure at least two hours to cut, and patch a hole the size of a quarter at minimum. Almost always the rust extends twice the size of the hole, and most shops will start at $40 an hour on the low end, up to $90 an hour. Whatever you do just don't think you can primer, fiberglass, foam, or bondo the rust. It will get worse, and you won't know about it because you've covered it up. I bought a 79 blazer, from a guy that did the bondo, and paint trick on the floor. I knew the floor had a few bad areas but let it go for a few years, and when I decided to go in and do my patch work, I ended up cutting out the entire floor, and rebuilding my own with raw sheet metal, including all the braces. It has taken me at least 100 hours so far, and it wasn't fun. Fix it right, or it's best to leave it for now.
I will be putting up a build thread for the floor in a few days for all those interested.
Old Mar 15, 2012 | 12:58 PM
pettyfog's Avatar
When it comes to doors and hatches and tailgates rusted out where the lower lip / inner door / trim seal / stamping come togehter.. dont waste your time and money. Get new.. or at least better. Anything you do to them will rust out again in a year or two.
Even if they dont see another teaspoon of salt. Been there!
Old Mar 15, 2012 | 07:30 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
Good advise from everyone. I'm looking forward to defiant custom's build thread.
Chic_Bowdrie
Mar 31, 2012 08:47 AM
Spectreblazer
Feb 2, 2010 07:42 PM
S10Blazer
Dec 6, 2009 01:58 PM
ComputerNerdBD
Jun 30, 2009 11:59 AM
firefighter9556
Nov 29, 2007 11:01 PM
