need carpet help
i recently not thinking filled up a 2 gallon gas can n put it on my back seat.....and hit a curb and the gas poured all over my carpet and now my car reeks of gas fumes can some1 help me with how to get rid of that nasty smell?
First, before using anything powered near your truck, make sure you are in a well ventilated area and that any ignition sources are as far away from the truck as possible. I know it may not be completely practical, but have it outside on a breezy day and take some degreaser and a carpet cleaner. Keep the power unit of the carpet cleaner as far away from the interior and up wind. Spray on the degreaser and scrub with a throw away brush. Then use the carpet cleaner to pull up the liquid. Repeat until all you smell is the degreaser.
Next time, buy a rubbermaid tub that fits your gas can and make sure that it is either strapped down or located somewhere that it cannot tip.
You will specifically need a degreaser to lift the gasoline from the carpet. I would start by getting some simple green concentrate (walmart in the automotive cleaners section IIRC). Mix it per the instructions on the back (probably a 5% solution to start). Have that in a spray bottle and liberally apply it to the affected area. At that concentration, you shouldn't need to test it in an inconspicuous area, but test if you want.
I use a pretty liberal concentration when I wash my shop clothes, rags, etc.
96jimmyslt4x4
Feb 26, 2011 10:10 PM
PhillyZ
Oct 6, 2009 02:10 AM
