Need help with HIDs
Old Dec 26, 2008 | 07:22 PM
NVANZEE's Avatar
Default Need help with HIDs
Im installing an HID kit and dont know where i should mount the ballasts. I do take my blazer on the trail every now and then so it needs to be somewhere were it wont get covered with mud and stay as dry as possible.
Old Dec 26, 2008 | 07:43 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Default RE: Need help with HIDs
Well i just mounted a set of HID's and i mounted the ballasts to the side of the mounting harnees of the grill acessabley accesed itfrom removing the headlights Iscrewed into the plastic section.It worked out well for me.
hope this helps.
Old Dec 26, 2008 | 11:25 PM
WolfPack's Avatar
I can get a pic for ya of mine if ya want, but I put the passenger side one flat on the top part of the plastic air scoop, even with the lower part of the grille plastic. The drivers side in the same spot was not hard plastic, just the flimsy rubber. So the drivers ballast is on the lower part of the air scoop below the radiator.
You just gotta play with em and see where they fit
Old Dec 27, 2008 | 02:05 PM
NVANZEE's Avatar
no thanks i already installed them. Thanks though
Old Dec 27, 2008 | 02:41 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
if u want you can post somem picks cause i mounted mine to the side nere the grill jwing to see where urs are
98Ltblazer
Apr 20, 2010 05:34 PM
mikeinwi
Jan 3, 2009 05:44 AM
NoPh33rRaCiNg
Jun 28, 2008 03:05 PM
cameronp29
May 25, 2008 08:23 AM
ChevyRacing88
Feb 27, 2008 03:01 PM
