New Custom Speaker Box
Old Jun 29, 2012 | 03:42 AM
Juggolow22's Avatar
Juggolow22 is an unknown quantity at this point
Default New Custom Speaker Box
I decided to to put a new speaker box in my car because i had no trunk space. So i bought some wood and did it my self. This is my first box lemme know what you think.
Old Jul 1, 2012 | 05:49 AM
Juggolow22's Avatar
Damn no comments?
Old Jul 1, 2012 | 08:05 AM
chris015's Avatar
I like it,any pics of the final product? Whats going in it and did you figure in what size it needed to be for the subs?
Old Jul 1, 2012 | 01:17 PM
Juggolow22's Avatar
I'm still at the resin stage. Gotta bondo it now. But I measured the speakers and it's gunna be 4 12" speakers. Two bass mtx and two ev speakers for voice.
Old Jul 1, 2012 | 02:33 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
i hope that u calculated the right air space for them and just didnt decide to build one that you like as speakers need a certain cubic feet to perform like they should....
Old Jul 1, 2012 | 03:11 PM
chris015's Avatar
Exactly what i was going to say. Juggolow if you didnt calculate what the subs needed for airspace then i doubt its going to sound like it should.
check this out
Speaker Enclosure Volume Calculator
read it over and it can help you. If you dont know about the specs on building custom box's,unless you build the box to have the right amount of volume for what that sub requires for its max efficiency then its just not going to sound right. Building a sub box isnt just making a box,and cutting out holes,Much more then that. If you already knew all this then great,maybe someone else that doesnt will come along and read this.
Old Jul 7, 2012 | 03:57 AM
Juggolow22's Avatar
Exactly what i was going to say. Juggolow if you didn't calculate what the subs needed for airspace then i doubt its going to sound like it should.
check this out
read it over and it can help you. If you don't know about the specs on building custom box's,unless you build the box to have the right amount of volume for what that sub requires for its max efficiency then its just not going to sound right. Building a sub box isn't just making a box,and cutting out holes,Much more then that. If you already knew all this then great,maybe someone else that doesn't will come along and read this.
I did calculate it. Thanks for the info tho. i started building one then had to take it apart because it wasn't calculated. This is the speaker system now. just waiting for all my speakers to come in. These are temporary. But its sick i like the way it sounds. I might put a dock under to make it sit higher.
Old Jul 7, 2012 | 04:10 AM
Zzzblazer95's Avatar
Zzzblazer95 is on a distinguished road
Looks pretty sweat nice job should have a divider in between all speakers so they dont work against each other fast way to blow your subs
c3478493
Feb 3, 2014 02:56 PM
caprini83
Apr 30, 2011 10:42 AM
butters
Jun 29, 2010 06:01 PM
rabbit0102030
Dec 5, 2006 09:27 AM
01xtreme
Jan 1, 2005 10:06 PM
