Overhead Console Wiring?
Old Jul 3, 2011 | 10:19 AM
robertfireye's Avatar
robertfireye is on a distinguished road
Default Overhead Console Wiring?
My 2000 4d was pretty basic when I got it and I'm just adding some premium stock options to it. I have gotten to the stage where I want to add an overhead console. There's never been anything up there except the basic dome light, and I don't want to take the headliner down for nothing. Is the wiring for an overhead console up there? I've seen a lot of wires going up the left pillar but I want to be sure. Any answers are appreciated.
Old Jul 5, 2011 | 04:52 PM
NWCoffee1's Avatar
NWCoffee1 is on a distinguished road
Smile Overhead Console Wiring
I found a 97 GMC Jimmy 4-Door that has the Overhead Console that will fit directly into a 95 Chevy Blazer 4-Door, make sure you get the overhead console, the headliner (plus the screw holders) that's above the headliner,
to hold the console into the headliner, the L/R luminated sun visors, that is if you want those, then the wiring that leads from the overhead console, the sun visor's, follow the wiring from the top going down the inside of the driver's side left pillar, down underneath the dashboard which
will lead into the main bundle of wiring. Unplug your wiring for the overhead console and carefully snake it out through the area of where the
fuse box is, but also, get the female end of the wiring plug ( from the main
bundle of wiring), just in case you have to do some re-wiring, so you can
get juice to the overhead console. It may take a couple of hours to re-install. Good luck on your project!
NWCoffee1
Tacoma, WA
Old Jul 5, 2011 | 05:29 PM
warthogdriver's Avatar
if your gonna go with the console which display are you going to use?
you also need to grab the outdoor temp sensor for the temp on display...i think it is located just behind the grille....and the newer displays have the compass electronics in the overhead with the display.
you will need both of those parts for the temp and direction to work.
if you go with the mpg display that simply needs to be wired to the obdII scanner output under the dash on drivers side.
there is a how to on this in the tech section.
also if you grab one from the yard be sure to take a foot or so of the harness with you.
Old Jul 6, 2011 | 12:51 AM
Talking
Well, I ended up purchasing my overhead console from a place I know pretty well over the phone. It's a long tan one with the mode button. I did this because I have been to several salvage yards with no result. One Saturday I looked at over 30 Blazers and only about 3 were 98+ and were completely stripped out, even the dash. But I snagged a temp sensor out of a 97. This is my first attempt at embedding images, so here goes. These are the wires running into my headliner. I figure that I have the six pin connector already up there but I'm really not sure. I was hoping someone here on the forum would. I don't know what that mystery wire by the windshield is either. This is what I currently have though. It is an old pic before I got the pwr/htd leather seats from the same place.
I am just hoping that it will be prewired for this stuff since the cluster seems to run up there.
Old Apr 7, 2012 | 03:34 PM
Motocross16's Avatar
Motocross16 is on a distinguished road
I've been wanting to do the same thing! I just wasn't sure if there were wires up there or what all i even needed to do to install one. Did you get yours to work?
Old Apr 7, 2012 | 04:04 PM
pettyfog's Avatar
He hasnt posted since Sept and I think you are going to have to start where he left off.
thing to look for is at top of pillar, if it branches toward headliner over windshield.. see any other reason for it to do that?
Pay attention to warthog's post, above
Old Apr 10, 2012 | 05:19 PM
Haha, I haven't done anything to it yet. I have located an overhead console that has the mode function and homelink buttons. (Jackpot!) I still haven't even dropped the headliner but I suspect I am prewired for the basic temp/direction console. I have also located a full wiring harness for a console with mode functions and I plan to just replace the old one, harness and all. Whenever I get around to it I'll post an update.
fortheson33
Apr 9, 2015 06:13 PM
nuwave
Jun 21, 2011 11:15 PM
radman2112
May 8, 2011 07:44 PM
cherryred4x4
Apr 2, 2006 12:29 AM
Pugsley
Feb 3, 2006 10:11 PM
