Passenger Door removal
Old Jun 20, 2008 | 10:29 PM
adanac's Avatar
adanac is an unknown quantity at this point
Default Passenger Door removal
I need to remove my passenger door on my 93 Blazer. Do I need a special tool to press out the pins? Has anyone removed thier door(s) before that could give me some tips please. Ive got a badly damaged door skin and have a replacement doorbut am not sure how to get pins out and if they're re-useable?
Thanks Mark!
Old Jun 21, 2008 | 04:33 AM
Default RE: Passenger Door removal
I wouldn't reuse the pins with as cheap as the replacement pins/bushings are.
Basically, just remove the spring (light truck door spring compressor from Eastwood.com makes this a ton easier), then drive the pins out with a punch and a hammer. If you have air tools available, they make anvils for an air hammer that make this job even easier. You will obviously have to have the door supported somehow. The last couple sets of door pins that I replaced, I just used a floor jack and a friend to hold the door, but a door jack works wonders if you are doing it alone. If you have any body shop friends, you may be able to talk them into letting you borrow a door jack.
Of course, before you get to taking the door off, you need to disconnect all electrical wiring inside and feed it through the hole in the door so it doesn't hang you up when you go to pull the door loose.
Good luck!
Old Jun 21, 2008 | 06:22 AM
adanac's Avatar
Thanks alot Swartlkk! The last time I removed doors it was on my 83 Olds 98 and it had bolts fastening the hinges so I would just take the whole assembly. Thanks again it's off to remove a door!
Mark.
kickme005
Jul 17, 2010 09:33 PM
bigdaddykane93
Dec 6, 2009 05:28 PM
treysanatomy
Nov 3, 2009 02:00 PM
bp2935
Feb 2, 2008 02:25 PM
a_tack
14
Jan 31, 2007 04:22 AM
