Passenger door will not stop leaking
Old Jul 11, 2012 | 12:50 PM
MikeTastic's Avatar
MikeTastic is an unknown quantity at this point
Default Passenger door will not stop leaking
So when i got the blazer the passenger door had a leak so i replaced both seals and its still leaking.
Ive checked the door hinges and all. theyre good. theres no slack in it. any ideas? solutions?
any help is appreciated.
Old Jul 11, 2012 | 12:54 PM
warthogdriver's Avatar
when you slowly close the door does it go into place smoothly or can you see it go up slightly?
you may have a bad door hinge bushing...mine went out and i developed a small leak along angled portion of the door frame.
just a thought.
Old Jul 11, 2012 | 01:29 PM
MikeTastic's Avatar
No, it has little to no movement in it when i shut it.
Old Jul 11, 2012 | 02:23 PM
Coddrick's Avatar
Coddrick is on a distinguished road
It really does sound like a door hinge issue, when you checked bushings what were you looking for? My driver door didn't sag at all, the old bushings looked good even when I took them out, but the only symptom i had was a slow drip onto my power window switch. If you open the door about half way, and lift from the bottom, can you move it up or down any? If not I'm really out of ideas.
Old Jul 12, 2012 | 12:06 AM
MikeTastic's Avatar
I just dont know. i guess that will be the next thing i do. see if that helps any.
Old Jul 12, 2012 | 05:19 AM
coolasice's Avatar
coolasice will become famous soon enough
are you sure it's coming from the front door? possibly heater core or condensate drain plugged? my leak was the rear door seal, parked on a downhill and it pooled in the front...
Old Jul 12, 2012 | 09:01 AM
MikeTastic's Avatar
Yeah. I sat in it while I got my dad to hold a water hose at the top of the door. It's coming in right in the bend of the door.
S.Hafsmo
Sep 17, 2013 02:50 AM
dannyb91979
Jul 16, 2013 06:08 PM
mjw1991
Sep 23, 2012 08:00 PM
mjw1991
Aug 3, 2012 11:50 PM
cr8390
May 11, 2009 10:25 PM
