rear bumper end tail lights?
Old Oct 5, 2009 | 09:08 PM
Deezy Steez's Avatar
Deezy Steez is on a distinguished road
Cool rear bumper end tail lights?
i bought my 98 ls 4dr about a month ago and since then ive completely debagged it and removed almost all of the tacky moldings that came on this year. ive been planing on removing the small molding strips on both rear bumper ends but havent done so because of the three guideholes that would be left in the bumper ends where the molding had been.
rather than filling the wholes and repainting the whole ends i thought it might be interesting to fit small red led's in the wholes and wire them so that they would come on with the brake lights.
any thoughts? other suggestions
Old Oct 6, 2009 | 07:36 AM
blazerguy22's Avatar
that wouldnt be bad but i would wire them into the brake lights and turn signals so that they flash one side or the other when you have your turn signal on>????
Old Oct 6, 2009 | 07:42 AM
yeah of course, make them run in unisin with the brake lights, but im not sure if its quite as easy as it seams, i may have to drill through the body to run wires into the bumper from the taillights
it might be a neat custom look though
Old Oct 6, 2009 | 07:48 AM
Sisk's Avatar
Hmm...interesting idea. I think if you got it wired up right it might look cool. Do you have a pic of where the holes would be? I can't picture where they would be.
Old Oct 6, 2009 | 07:56 AM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
Or just replace the bumper ends with ones without the holes. If you do the lights you just need to tap in to the trailer wiring harness, no need to drill into anywhere.
Old Oct 6, 2009 | 12:36 PM
Unlimitedsp's Avatar
I think that would be a neat idea if done right. You could tap a small hole underneath to run the wires and just splice them in to the tailight harness.
Old Oct 6, 2009 | 12:53 PM
Sisk's Avatar
This is a good idea. It would be simple to tap into the trailer light harness, and it would work exactly how you would want it too.
Old Oct 6, 2009 | 04:34 PM
yeah the wiring from the trailer harness is actually a perfect idea. it's hard to describe where the holes would be, but there would be one small one on either side of the rear bumper and then two facing towards the side of the truck on either side. this way i can keep the stock paint and bumper ends and save myself 100+ dollars for new bumper ends. Only other question i might have is whether there would be any legal issues with having the lights facing to the side of the truck? any thoughts?
Old Oct 6, 2009 | 07:06 PM
Zeeke98's Avatar
Side markers would be fine but I wouldn't hook the side ones up to the brake lights. You can use them as turn signals though. Brake lights are only supposed to be rear facing, but turn signals are required on the sides front and rear per Michigan law. I'm sure other states are similar.
ff162bfd
Oct 26, 2009 11:23 AM
sidviscious
Oct 8, 2009 08:38 PM
94camaro
Dec 15, 2008 07:32 PM
blazerboy124
Nov 6, 2008 10:47 PM
98BlackBlazer
Aug 28, 2006 01:31 AM
