Removing paint from vinyl?
Old 02-25-2009 | 07:34 AM
hubbmatt's Avatar
hubbmatt is an unknown quantity at this point
Default Removing paint from vinyl?
I had a little boo boo when I painted my arm reset and I want to completely strip the paint off before the 2nd go around. What should I use so I don't damage the vinyl???
Old 02-25-2009 | 07:48 AM
IROCZ's Avatar
IROCZ is an unknown quantity at this point
Default RE: Removing paint from vinyl?
try some thinner
Old 02-25-2009 | 09:53 PM
encryptedzion's Avatar
encryptedzion is an unknown quantity at this point
Avoid products containingAcetone since that will degrade/damageplastic (vinyl).
Products containing Isopropyl Alcohol will not degrade/damageit. Or use straight Isopropyl Alcohol,pour it on to a cloth/rag and use in a well-ventilatedarea at room temperature. It will not leave a residue after it oxydizes (dries) either...but it may takea couple of"clean areas" on the rag to get it all cleaned-up.Depending on the amount of paintneeded to remove, it may take some time and scrubbing to remove the material.
Hope this helps!
Kaegael
05-05-2014 08:46 AM
Unlimitedsp
01-18-2010 04:59 AM
Unlimitedsp
12-03-2008 01:09 PM
Andyking1243
10-06-2008 11:42 PM
Quick Reply: Removing paint from vinyl?
