removing windshield trim on first gen
is it possible to remove the windshield trim on a first gen without removing the whole windshield. I was washing the truck at a coin wash with the pressure washer rinsing it, and noticed the windshield has a small leak. I already made a thread about fixing rust above the windshield that has gone below the trim a bit.
So, I could kill 2 birds with one stone if the trim will come out without removing the whole windshield.
I really do not want to have to pay a glass company to come, remove the windshield for me to fix the rust that is not far under the trim, and then come back later to put it back in. that does not sound like it would be cheap, and would run the risk of breaking the window when they are taking it out.
What a relief knowing I do not have to remove the whole windshield to get the trim out.
Thanks again
and for getting it on me, elbow length rubber gloves LMAO
Thanks again
*edit*
The urethane windshield glue is not that much, i was expecting 50 or so with the way you described, I can get 10.5oz of 3m urethane windshield adhesive for no more than 15 bucks.
That is the thing, I do not want to remove the glass.
I want to just remove the trim, fix the rust that goes slightly under the windshield trim, seal up around the window and put the trim back on.
The reason i do not want to have the windshield removed is because they would come out. remove it, leave it somewhere on my property and leave, while I fix the rust, then later on in the day, or the next day, come back, put the windshield back in. seems like more of a PITA than just removing the trim and fixing the leak and rust myself.
