Replacing seats
So I was walking around the junkyard the other day and I found a 97 Jimmy with pristine leather seats. I have an 02 Blazer, and I figure that the Jimmy seats probably won't fit exactly into the Blazer (because of the year difference), but how difficult will it be to mod the Jimmy seats to fit? Thanks in advance.
-Matt |
They should be basically the same thing. They're both second gens. You should be able to take yours out and put those in there no problem
Yup! Should be a direct fit!
Thanks guys. Now for the second question: My current seats are manual adjust but the leather seats are power adjust, should I attempt to wire them in or just bolt them in where I want them? The seat motor seems to be self contained, so I figure I just need to hook some power into it by tapping into the fuse box. What do you think?
Originally Posted by mlapinski23
(Post 324220)
If your skilled enough at wiring or can afford to pay someone who is then I would say go for it if not I would say just leave it.
Not exactly sure on the harness, but I think it's worth a shot. I've been searching around both on and off the forum for the seat wiring schematics without any luck. Looks like I'm just going to have to blaze a new trail in seat wiring :icon_shrug:
i've tried to get leather seats out of a 98 olds bravada to fit in my 96 blazer and they didn't fit.
Hmm, why exactly. Different mounting points?
I just did this today to my 98 jimmy 4dr, The seats are from my 97 bravada. The front 2 bolts line up no problem So does the outer rear bolts, The inner rear seat bolts dont line up but 3 of 4 bolts hold the seats just fine. For power just tap into fuse #20 and run a ground to the seat bolt. Make sure you cut the seat plugs out of the donor vehicle so you can run the wires, And plug in your seats nice and simple.
Originally Posted by blazerboy001
(Post 324428)
| All times are GMT -5. The time now is 12:03 PM. |
