Rust above windshield
Old Dec 21, 2011 | 04:12 PM
richphotos's Avatar
Default Rust above windshield
I have some rust above my windsheld that I am going to want to fix in the spring, its not REAL bad, but its rust, so its not good, it looks like it goes under the windshield trim a bit, What I want to know is, how hard is it to take out, and put back in a windshield when it is warm enough to fix it?
Old Dec 23, 2011 | 02:49 PM
richphotos's Avatar
Nobody, from what i have read i have to have someone from a window place come out and remove it for me since they are glued in
Old Dec 23, 2011 | 03:55 PM
Zanders's Avatar
Zanders is on a distinguished road
you are probably correct on having a professional remove and replace your windshield, just so everything is sealed correctly. As for the ideal temperature, you can sand rust off whenever, but as for painting it i believe ideal temperature is 50 degrees Fahrenheit, but check your paint can for that, it'll say it. So unless you have a heated garage i would wait for a while and keep the salt away from it. And remember, prime, paint, clear coat it.
Old Dec 23, 2011 | 06:26 PM
richphotos's Avatar
Thanks, The body work and painting is the easy part, since that is one of the side hobbies of mine, but the removal of the windshield I have never had to do, figured i was going to have to have someone come and take it out for me and come put it in later on in the day. Thank!
Old Dec 23, 2011 | 08:30 PM
MrJP's Avatar
MrJP is an unknown quantity at this point
I am no authority, but as I understand it, if your blaze has airbags, the windshield is a structural member and has to be glued in. They have to withstand the preasure from the airbag.
Old Dec 23, 2011 | 10:55 PM
richphotos's Avatar
No airbags, Its a 1993 jimmy, So, does that mean that it is not glued in? that would be awesome!
Old Dec 24, 2011 | 12:55 PM
j89lumaye's Avatar
j89lumaye is on a distinguished road
Nope, there glued, at least a 91 s10 is. and myold 92 blazer
Philly Frank
Jun 25, 2012 11:22 AM
Chic_Bowdrie
Mar 31, 2012 08:47 AM
peters702
Jan 29, 2010 10:50 AM
aypapi
May 24, 2007 12:47 AM
zashwood
Headers, Intake, & Exhaust
Sep 7, 2006 08:51 AM
