rust hole in rear passenger door into wheel well
Old Mar 12, 2014 | 11:04 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default rust hole in rear passenger door into wheel well
i developed a rust spot from my rear passenger door jam into the wheel well...the hole is about 2x3 in the door jam, and about a 1x1'' in the wheel well.
i cleaned it all out which is why the hole is bigger, should i just bondo the hell outta it? or is there a better option
pictures can be provided if needed,
thanks in advance
Old Mar 12, 2014 | 11:39 AM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Expanding foam, and bondo. I have the same issue you do, I might take a sawzall to pic a part with me one day and have at it.
Old Mar 12, 2014 | 12:21 PM
newguy's Avatar
Yep foam, not the best fix because it holds water but the easiest and fastest. Heck gm put foam in there anyway to quiet sound. Thats why there`s rust!
Old Mar 12, 2014 | 02:13 PM
er0ck273's Avatar
Is expanding foam something I can purchase at Walmart? Lol. Yea the foam already in there is soaked. ..shocker...since its hollow inside, should I get the wet foam outta there and buy the bondo self adhesive mesh and go about it like that?
Old Mar 12, 2014 | 03:45 PM
newguy's Avatar
Depends how pro you want to be. Expanding foam (yes walmart) spray it in, let expand and cure, trim flush, sand around the edge to expose metal, bondo or fiberglass sand down and paint
Old Mar 12, 2014 | 07:50 PM
er0ck273's Avatar
Gonna head out and grab all the remaining supplies including expanding foam. Thank you for the great advice guys. Will hopefully have some before and after pics sooner than later....cant keep up with this damn weather lol
Old Mar 13, 2014 | 09:47 AM
er0ck273's Avatar
so this is what im dealing with, gonna tear some more out and take out the wet foam before i start re-foaming
Attached Thumbnails rust hole in rear passenger door into wheel well-20140312_124243.jpg   rust hole in rear passenger door into wheel well-20140312_124252.jpg   rust hole in rear passenger door into wheel well-20140312_124309.jpg
Old Mar 13, 2014 | 12:33 PM
richphotos's Avatar
If you REALLY want to go the foam route instead of welding in some new metal.
Search around on the internet, I believe there is some expanding foam that resists water if I have read correctly. Do some searching first.
Old Mar 13, 2014 | 03:20 PM
er0ck273's Avatar
say i dont use foam at all, i did buy it but can return it. would it hurt anything? i know its basically used for soundproofing.
Old Mar 13, 2014 | 03:28 PM
newguy's Avatar
You would need access to a welder or someone who welds to fix it properly. Depends how llong you plan to keep or how long you think the truck will last you. Foam and bondo 2-3 years, cut out ALL the rust and weld 10+
