Is there a trick to removing ZR2 fender flares..???
Old Nov 23, 2010 | 07:07 PM
DPBlazer01's Avatar
DPBlazer01 is on a distinguished road
Default Is there a trick to removing ZR2 fender flares..???
Really need help.. Just spent past hour trying to get one front flare off..All screws are out ..Looked at all the info I could find.. they all say "gently pry off from 1/2" lip" .. I pulled as hard as I could and thought It was going to snap off.. No Go...
Factory repair manual says remove the fender first..!!!!
Please tell me that does not have to be done..
Is there a trick I'm missing that you guys have used ??? I see plenty of threads that mention you have all pulled them off...how..??
Rear looks easier... I hope to just drill out rivets..
Thanks
Dean
Old Nov 24, 2010 | 12:44 AM
AuburnBlazer's Avatar
AuburnBlazer is on a distinguished road
i thought they were on there with special double sided tape,
Old Nov 24, 2010 | 08:53 AM
AJBert's Avatar
To pull the fronts correctly you do need to remove the fenders. There are a couple more bolts/nuts that you can't get to unless you remove the fenders. The rears are pretty easy, though.
Old Nov 26, 2010 | 04:04 AM
Moores12345's Avatar
Moores12345 is on a distinguished road
I thought they were on with screws and auto double sided tape, with little effort they should pry off.
Old Nov 26, 2010 | 09:17 AM
AJBert's Avatar
Nope, studs on the flare side that pass through the fender lip and held on with nuts.
420Blazin4X4
Oct 2, 2012 07:22 PM
gatorboy44
Apr 1, 2012 07:04 PM
Licklog
Nov 20, 2009 09:55 AM
Shredder
Apr 21, 2009 07:40 PM
Brian J. Lesko
Mar 23, 2006 12:07 PM
