Tire carrier welded nut let go
to access the part where the hinge bolts to the body on the side? i think so. my 93 had the tire carrier and the interior has been gutted and roof cut off and i dont remember ever seeing any access panel or anything
I would try to get at it through the wheel well. See if you can separate the sheet metal under there from the quarter panel or maybe just cut an access hole. I'm at work and can't go out to look at mine to come up with anything better.
There has to be some way in there. I have never removed one on an s-series, but there have been a few people that have added them on.
What can you see when you remove the tail light? How about up from directly under the truck?
Now that I think about it, you might be able to get to it by removing the plastic trim inside. If you open the access to where the jack is stored I believe you can see the inside of the fender. Should be the same on the passenger side by removing the plastic panels and whatnot.
DarkKnightBlazer
Headers, Intake, & Exhaust
Jan 17, 2014 08:32 PM
bigdaddykane93
Dec 22, 2009 12:29 PM
