Tire carrier welded nut let go
Old Feb 26, 2010 | 05:50 PM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
Default Tire carrier welded nut let go
How do I access behing the mounting points for the spare tire mounting brackets? Do I need to cut a hole?
Old Feb 26, 2010 | 10:37 PM
abig84's Avatar
to access the part where the hinge bolts to the body on the side? i think so. my 93 had the tire carrier and the interior has been gutted and roof cut off and i dont remember ever seeing any access panel or anything
Old Feb 27, 2010 | 02:25 AM
OILCOUNTRY's Avatar
Well this sucks... I really don't want to...
Old Feb 27, 2010 | 05:02 AM
AJBert's Avatar
I would try to get at it through the wheel well. See if you can separate the sheet metal under there from the quarter panel or maybe just cut an access hole. I'm at work and can't go out to look at mine to come up with anything better.
Old Feb 27, 2010 | 08:53 AM
There has to be some way in there. I have never removed one on an s-series, but there have been a few people that have added them on.
What can you see when you remove the tail light? How about up from directly under the truck?
Old Feb 27, 2010 | 12:22 PM
abig84's Avatar
There you go. Try taking the tail light off
Old Feb 27, 2010 | 05:20 PM
RangerG's Avatar
I don't think there is anything under the tail lights. I've changed mine out and never saw anything of interest. But then again, I wasn't looking.
Old Mar 1, 2010 | 06:06 PM
AJBert's Avatar
Now that I think about it, you might be able to get to it by removing the plastic trim inside. If you open the access to where the jack is stored I believe you can see the inside of the fender. Should be the same on the passenger side by removing the plastic panels and whatnot.
DarkKnightBlazer
Headers, Intake, & Exhaust
Jan 17, 2014 08:32 PM
doelleb85
Jan 11, 2012 12:34 AM
bigdaddykane93
Dec 22, 2009 12:29 PM
Biohazed
Apr 24, 2009 02:45 AM
stevo
Apr 8, 2009 06:52 PM
