Torx Size for Cargo Tie down/Grounding spot
Old Apr 21, 2021 | 03:06 PM
Musgrove's Avatar
Musgrove is on a distinguished road
Default Torx Size for Cargo Tie down/Grounding spot
Hi everyone-
I'm installing an amp in the back of my 2001 Jimmy SLS and I need to find a good ground spot. I don't want to drill a new one, and the existing ones are near impossible to access. So I was thinking of using where the ties down are in the cargo area. I don't know what size Torx bit to use, though and even if I get the clip off, do you think this will yield a good spot for grounding, if I Dremel away any paint to get to the metal underneath? Does anyone know of a better spot if so?
Thanks,
Michael
Old Apr 21, 2021 | 03:33 PM
I don't know the size of that. But I used a bolt on one of the back seats
Old Apr 23, 2021 | 09:53 AM
Musgrove's Avatar
If I could access one of those better I'd use them, but the angle they're put in, with the seat in font of it, makes it impossible to unscrew without taking the seat out. That's too much trouble. There must be an easier way.
Old Apr 23, 2021 | 12:15 PM
I did it with the seat folded down, and the flap folded up. Straight access...
I believe the access should be the same on the 2 doors under the plastic flap. Try and get a pic today.
Old Apr 23, 2021 | 12:54 PM
Flap that covers gap when seat folded
Rear seat bolt. Dont mind the mess
T50
Old Apr 23, 2021 | 08:12 PM
Musgrove's Avatar
That's a HUGE help. Thank you so much!! My problem was that I'm an idiot and wasn't pulling the seat forward enough to even see the bottom bolts, just the ones at a 45-degree angle. And even then I wasn't pulling the seat forward enough. I just bought this truck so I'm learning what's what and with a lot of things, if you have to force it, you're probably doing it wrong. And I thought I was forcing the seat forward and didn't want to break something.
Thanks a million for your help. You saved the day!
Trukntigger
Mar 18, 2019 10:54 PM
Steve-o
Feb 21, 2014 05:11 PM
ecksrichecks
Nov 4, 2013 08:41 AM
breakjaw357
Feb 8, 2009 09:34 AM
Blazin_1t_up
Tires and Wheels
Sep 13, 2008 12:37 PM
