tow hitch
Old Jan 9, 2006 | 11:48 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
Default tow hitch
does anyone know if the tow hitch in the rear bumper of the newer blazers is sturdy?all it really is is a place to screw the ball into......i want to know if it is a good place to attach a tow hook...any advice?
Old Jan 15, 2006 | 05:24 PM
20Blazer00's Avatar
Default RE: tow hitch
Check the owners manual or the dealer to find out the rating on the bumper. It may not hold as much as you need to use the hook for. It should not be a problem to mount a hook there but I would look into a reciever adapter that mounts to that location then you could remove the hook until you really need it....
Search sites like hitchsource.com and others to find the part. I recently purchased a frame mount reciever hitch from them instead of trusting the bumper.
I checked on truckperformance.com and Putnam MFG. makes a step bumper box for approx. $40 that would fit this description rated at 5,000lb but your bumper must be rated to take advantage of the full 5K, they also make lesser rated hitches too...
mattjphoto
May 31, 2011 10:16 AM
irishballer814
Jul 12, 2010 07:10 AM
CBlazer99
Nov 12, 2009 05:32 PM
nbwebb
Mar 12, 2007 02:05 AM
Madwahoo
Jan 25, 2007 08:25 PM
