Trim Removal question
Old Jul 5, 2009 | 01:27 PM
smoke03's Avatar
smoke03 is on a distinguished road
Ive got a 2002 Chevy blazer LS and the clear coat on the trim is coming off and really lookiong bad. this isnt the black plastic trim its the trim thats painted the same color as the blazer. Im sure they painted the blazer and then stuck the trim on, correct? I did a little searching for info on removing it but couldnt really find anything. How hard is it to remove and what should I use for removing the glue?
TIA
Ben
Old Jul 6, 2009 | 04:02 PM
smoke03's Avatar
any body got any input?
Old Jul 6, 2009 | 04:19 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
are you talking about removing the moldings?? if so its been covered numerous times. most people use fishing line and slide it between the body and the molding then to remove the glue you can either use your thumb or your choice of adhesive remover.
Old Jul 6, 2009 | 09:15 PM
smoke03's Avatar
sorry guys...I tried searching and never found anything but then today I finally found something...cant beleive it took me that long. ANYWAY....I got my fishing line out and the WD and alchohol and gasoline and got everything off...Looks SO MUCH BETTER NOW!!! thanks for the help
Cavalier z24
Jul 18, 2012 10:54 PM
JRock1944
Feb 10, 2012 06:31 PM
collinb1234
Dec 19, 2011 04:43 PM
tycobb280
May 10, 2011 08:45 PM
SureShot
Nov 24, 2009 03:13 PM
