trimming fenders
Old Nov 19, 2007 | 10:05 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default trimming fenders
I just got this sweet set of four 33 inch tires off a gmc jimmy so i want to know what i half to do to get my stock 96 blazer 2wd to fit them if i trim the fenders will that be enuff . im kinda broke for the lift kit.. any ideas..in order for the jimmy to have them was there a lift kit on it? i dont think cause i seen the wheel well was sharp from rubbing..any help is appreciated
Old Nov 20, 2007 | 08:48 AM
Banned
Default RE: trimming fenders
ANY 1? PLEASE ANY1?
[/align]
Old Nov 20, 2007 | 08:56 AM
cliro's Avatar
cliro is an unknown quantity at this point
2 inch suspension lift, 2 inch body lift, and some trimming needed.
instead of getting into a panic looking for answers try the search button, there are probably pages of info related to your question.
Old Nov 20, 2007 | 09:06 AM
Banned
appreciate it, can u give me a cheap estimate?
[/align]
Old Nov 20, 2007 | 09:24 AM
cliro's Avatar
doing it all yourself will be $300-$400
rear shackles can be $50-$100
torsion twist - free
body lift $150-$250
wheel allignment $60-$80
trimming fenders- free.
Old Nov 20, 2007 | 11:18 AM
mdehoogh's Avatar
you may also need new wheels. most 33" tires are 12.5" wide which is too much for stock wheels. in THIS THREAD Hanr3 explained that the max tire width on stock rims is 11.5"
ORIGINAL: Hanr3
ORIGINAL: jdblazin
I just wanted to thank you for serving our country and welcome home.[sm=patriot.gif]
Just my opinion; I think I would want to use a little wider then stock rim with 12.5's
General rule of thumb is 4"-4.5". The tire can be a maximum of 4.5" wider then the rim. Your stock rim is 7", that puts your max tire width at 11.5", 12.5 are too wide for your rim. Another thing to do is check with the tire manufacture, they have recommended rim dimensions for every tire they make. Most have that info posted on-line at their website.
Old Nov 21, 2007 | 01:51 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
ORIGINAL: cliro
body lift $150-$250
2WD Blazers dont have torsion bars. You need lift spindles like those from fab tech. Either that or spring spacers work too and they are cheaper but dont lift as much in most cases.
Old Nov 21, 2007 | 03:26 PM
thegr81's Avatar
One thing to remember when lifting a 2wd it isa big recomendation to use lift spindles to maintain front end geometry so your other suspension parts to wear out faster, another thing is when using a lift spindle is to use tubularupper control arms they help big time with your camber, note to rob must find tubular upper control arms for yours lol!!
Old Nov 21, 2007 | 04:10 PM
RCars2's Avatar
ORIGINAL: thegr81
......yeah i know, would have made that afternoon much easier thats for sure, LOL!! Hopefully though next time the front end will need service will be for the install of a solid axle (oh yeah!!).
Old Nov 21, 2007 | 04:56 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
solid axle would be sweet, what kind are you thinking of puttin in
