trimming fenders
Old Nov 21, 2007 | 05:36 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: trimming fenders
As a minimum Dana 30 in the front, ideally a Dana 44 is what i want. For the rear either a GM 8.5 or Ford 8.8. Much of this depends on what i can afford/find. Either way it seems that I'll be switching to a 5x4.5 bolt pattern as they dont offer dana's with 5x4.75 shafts. Either that or ill just get spacers for the rear if i stick with a GM 8.5 and on the front ill do a spacer adapter that will change it to 5x4.75.
Old Nov 21, 2007 | 06:36 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
that will kinda suck if you have to change bolt patterns since you already have nice wheels. the project itself will pretty cool
Old Nov 21, 2007 | 06:40 PM
cliro's Avatar
cliro is an unknown quantity at this point
ORIGINAL: RCars2
ORIGINAL: cliro
doing it all yourself will be $300-$400
rear shackles can be $50-$100
torsion twist - free
body lift $150-$250
wheel allignment $60-$80
trimming fenders- free.
2WD Blazers dont have torsion bars. You need lift spindles like those from fab tech. Either that or spring spacers work too and they are cheaper but dont lift as much in most cases.
oops, my bad. i missed the 2wd part, figured it was 4wd
Old Nov 21, 2007 | 06:56 PM
RCars2's Avatar
ORIGINAL: cliro
ORIGINAL: RCars2
ORIGINAL: cliro
body lift $150-$250
Its all in the details, LOL. Its alright, we all miss stuff every once in a while. Thats why we are community, we help each other out.
Old Nov 23, 2007 | 12:03 AM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
cause ive been reading most people are curious about awd blazers some people told me there is none so i always figured mine was 2wd cuz no 4x4 but i looked under the hood and it says awd any care to explain?
[/align]
Old Nov 23, 2007 | 08:01 AM
rriddle3's Avatar
For some reason I was thinking that you have a 2dr model, but I show that the AWD was only available on 4dr models in '96. Which body style do you have? It would be easier if you would put your vehicle info into your signature so questions would be easier to answer. See mine for example.
CraigSnedeker
Tires and Wheels
Nov 10, 2010 10:13 AM
jester429
Mar 8, 2008 10:32 PM
flyinbrad
Oct 5, 2007 06:55 PM
flyinbrad
Suspension Tech
Jan 30, 2007 01:56 PM
