wiring?
Old Jan 22, 2007 | 11:39 AM
blazinjimmy94's Avatar
blazinjimmy94 is an unknown quantity at this point
Default wiring?
hey everyone,
I just bought blue lights the go in your grill, there like strobes. I no i have a power wire and a ground, but which is the best way to wire this up...where should i connect the wires to? thanx
Old Jan 22, 2007 | 02:28 PM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Default RE: wiring?
alright, you're gonna need a toggle switch. run both power wires to the toggle switch, and from the toggle switch, run one to your battery. you can ground both lights on the bolts that hold your bumper on. i did this with a set of foglights and it works beautifully.
Old Jan 22, 2007 | 04:44 PM
Default RE: wiring?
thanx. What about if i grounded it to the bumper bolt like you sed but instead of running the power to the batterey, how about running it to the fuse box, wrapping the aire around the fuse and sticking the fuse bak in?
Old Jan 22, 2007 | 05:53 PM
drperry's Avatar
Default RE: wiring?
Then the lights would ALWAYS be on, until the fuse burnt, depending on which side of the fuse is the hot blade.
If they're blue strobes, you do NOT want them running all the time, or else you'll be busted for imitating an officer.
Old Jan 22, 2007 | 07:42 PM
Default RE: wiring?
im running a toggle switch so i can put them on and off
Old Jan 22, 2007 | 07:47 PM
drperry's Avatar
Default RE: wiring?
You _could_ use a fuse in the box, but then you might start burning it, or causing other circuit issues... Don't skimp on wiring, you could burn things down.
Wire it to the battery with an inline fuse to your switch, then from the switch to the light.
phxjosh
Oct 30, 2013 10:03 AM
speedhead
Mar 16, 2012 06:54 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
joshzerofour
Feb 15, 2005 11:37 PM
chris
Dec 6, 2004 12:47 AM
