ZR2 fender flair
Old Sep 12, 2018 | 07:03 AM
man0steel's Avatar
man0steel is on a distinguished road
Default ZR2 fender flair
Fender trim between body and flair coming loose on ZR2. I removed the trim screws around the under side of the flair but that didn't loosen it up. It appears I need to pull the flair away from the fender so I can slip the trim piece back in. How do I do this?
Attached Thumbnails ZR2 fender flair-20180910_123802.jpg   ZR2 fender flair-20180910_123753.jpg
Old Sep 12, 2018 | 04:39 PM
N. Jensen's Avatar
I was under the impression that the little bit of trim is attached via an adhesive or somthing...? I always run across flares like this in the man mall.
Old Sep 14, 2018 | 09:13 PM
Theres bolts that go through the side of the fender(front), side panel(rear). If you loosen them, you can re-aligne the rubber...
and there is adhesive in the groove of the rubber before placed onto the flare. But like all double sided tape, it weakens and loosens...
420Blazin4X4
Jun 5, 2013 01:07 PM
lityjohn701
May 16, 2013 10:02 PM
Kyle_Richard
Feb 23, 2012 10:10 PM
DPBlazer01
Nov 26, 2010 09:17 AM
MCas86
Jun 22, 2006 09:53 PM
