ZR2 Spare Tire Carrier (ugly!)
Old Feb 22, 2010 | 12:27 PM
swizznuker's Avatar
swizznuker is on a distinguished road
Default ZR2 Spare Tire Carrier (ugly!)
My 2000 ZR2 has a spare tire carrier, factory. It sits on the back of the truck and does not look at all aesthetic.
I want to remove it totally, but there will be a problem: the tire will not fit anywhere! Can I just get a regular tire and mount it on the 15" factory rim, and use that as a spare? That way I could just put the new spare inside the truck, because my guess is the ZR2 does not have the hardware to undermount it, unless that is a possibility?
Old Feb 22, 2010 | 12:31 PM
wlorton's Avatar
Roof rack? and send the old rack to me? lolz
Old Feb 22, 2010 | 01:10 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Well real Strange right? You want to get rid of the tire Carrier and others would Love to have it ? I had a Black 2000 ZR2 with the Carrier, it was a Pain in the butt to see to back-up and and see out the back glass for me, Is it an aesthetic or just hard to see with the tire in the WAY ? Good Luck T.J.
Old Feb 22, 2010 | 04:38 PM
The_Beast's Avatar
The_Beast is on a distinguished road
I love the look of a tire carrier on a 2 door, IMO they don't look right without the carrier. But I'll admit that backing up is made harder by them (and the huge c-pillar doesn't help)
Old Feb 22, 2010 | 04:41 PM
Sisk's Avatar
You're one of the few that wants to get rid of the spare tire carrier as mentioned above. It's a very desired feature for many (and a lot of 4dr owners which is wasn't available on). I have a 2dr with it too, so I can understand your annoyances with it. It incrediby hinders your rear view and makes it almost impossible to see behind you, and the worse part is the glass won't open with the spare tire carrier closed (on of my pet peeves).
Anyway, if you are set on removing it you can. The 2drs aren't made for undermounted spares, but in all honestly you wouldn't want an undermounted spare. They are a terrible idea and a real PITA if you ever get a flat. That leaves the roof or inside as an option. A lot of 2dr's (those without the spare tire carrier on the back) have them mounted inside. The only disadvantage is you lose a serious amount of trunk space (nearly 50%). If this isn't an issue for you though I'm sure you could pick up a mount for one fairly cheap at a junk yard or something and put your spare inside. The other option is the roof. This would be my choice. Not only does it look bad ***, but it's easily accessible and very easy to do. You just need some straps. You can mount it to the roof rack, but a basket would be ideal.
As for your question about tires and it not fitting...I don't really understand your question? You're saying you don't want to use the spare rim?
Old Feb 22, 2010 | 04:43 PM
wlorton's Avatar
There are items on ebay that lower the spare so you can see....
Old Feb 22, 2010 | 06:36 PM
Hummmmmmmm, Never Seen that Item to lower the Spare? As My Father-in-Law Has my Ole Black 2000 ZR2, We did some horse trading and He now owns it, But also HATES the Spare Tire in the Way also. But We LOVE the Look. Got to find that kit for Him ? Thanks for the Info.
Old Feb 22, 2010 | 06:56 PM
The_Beast's Avatar
Link?
Old Feb 22, 2010 | 07:14 PM
Sisk's Avatar
The only issue with lowering the spare is that it will block your license plate, which is illegal everywhere. You'd either have to relocate your plate, or get pulled over frequently.
Old Feb 22, 2010 | 09:14 PM
old skool luvr's Avatar
i think he was talking about mounting a smaller tire, like the non-ZR trucks 235/75/R15 size, so that it'll fit inside easier/better.
personally, i'd mount it to the roof, like i did on my '92 4 door (God i sooooo hated that spare carrier out back!). i just made up a couple of cross bars, drilled & bolted to the side bars, with another bar running front to back between them (kinda like a big capital "I"), and just welded the actual mounting bracket from the rear carrier to it. this way it was bolted down secure, and could have one of the matched lock nuts on it so it couldn't "wander away".
