Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
86 blazer turbo
Old Jun 20, 2008 | 12:21 PM
slammed's Avatar
slammed is an unknown quantity at this point
Default 86 blazer turbo
i have an 86 s10 blazer slammed on the ground, i put a 3.8 liter 229 ci bored .40 over edelbrock aluminum intake, mild cam, and stock heads, edelbrock 650 cfmi was wondering if this motor would handle a 16g turbo only using 8 lbs. of boost.
thanks
Old Jun 20, 2008 | 12:44 PM
Default RE: 86 blazer turbo
What are you running for compression ratio?
Old Jun 20, 2008 | 01:45 PM
slammed's Avatar
thats just it im not sure but the pistons are just cast they're not forged or anything. so im not sure what its compression is.
thanks
Old Jun 20, 2008 | 02:51 PM
You really should try to figure it out even if it is just an estimate. If you are looking to run 8psi or more, you need to be down around 8.5:1 CR or you'll be putting some mighty expensive gas in!
Old Jun 20, 2008 | 04:20 PM
slammed's Avatar
how would i find out
Old Jun 20, 2008 | 06:28 PM
Head/piston/rod/crank specs would get you close.
If most all of those components are stock, you are probably looking at 9:1 to 9.5:1 CR. Depending on programming, you may be ok, but you would definitely have to get a good tune!
02 Vortech
Street N Strip
Jun 22, 2009 10:44 AM
02 Vortech
Jan 6, 2008 09:04 PM
02 Vortech
Feb 12, 2007 06:40 PM
Dan
Nitrous, Super Chargers, & Turbos
Jul 25, 2006 03:09 AM
2klt
Mar 3, 2006 01:10 PM
