Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
axle swap
Old Jun 15, 2013 | 07:12 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default axle swap
Would a 98 and up bravada axle fit 01 blazer?
Old Jun 15, 2013 | 08:34 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Yes,just need to make sure the gears are the same.
Check the rpo codes in the glovebox.
Old Jun 16, 2013 | 08:49 AM
01blazer16's Avatar
If I get one with 3.73 gears and mine has 3.42 gears will I have to change something I'm my computer to run 3.73?
Old Jun 16, 2013 | 10:01 AM
newguy's Avatar
You`ll have to change the gears in the front trans axle, thats all. find one with 3.42 gears
Old Jun 16, 2013 | 10:29 AM
50lb_cat's Avatar
I think the shift points may be off going to 3.73, someone correct me if im wrong. It can be fixed by having the pcm tuned.
Old Jun 16, 2013 | 10:32 AM
newguy's Avatar
Not positive but dont think so, that has to do with rpm`s I believe
Old Jun 16, 2013 | 10:38 AM
50lb_cat's Avatar
Good point, i know when i got my pcm tuned, he asked if i had stock gears or if i changed them, so i was thinking the pcm might need to know for some reason
Old Jun 16, 2013 | 11:04 AM
newguy's Avatar
guess it may be possible to change if wanted/needed
Old Jun 16, 2013 | 02:19 PM
01blazer16's Avatar
why would I have to change gears in front if I have a 2wd truck?
Old Jun 16, 2013 | 02:23 PM
newguy's Avatar
You did not state that earlier that makes things much easier. Still dont believe you need computer reprogrammed
