best chip/cold air intake
hey i was wondering what is the best chip/cold air intake for the 4.3 2000 blazer would be.
try running a search noth things have been discussed several times, but most true cold air intakes will give you the same results so whatever brand you go with is fine. as far as "chips" go i personally wouldnt waste money on one or any handheld youll get the most bang for your buck from a custom dyno tune or custom pcm tune, but like i said ealier just run a quick search do some research and decide whats gonna be best for you.
I've been happy with my K&N FIPK intake. I also have a custom PCM tune from Wait4Me performance.
I'm happy with the K&N too but, the only problem is that if you want to use a throttle body spacer you won't be able to use it with this brand.
TB spacers are just noise makers are our engines anyway.
I believe you can use the Air Aid Intake with their spacer. For a programmer Hyper Techs are nice but the best would be a tune with PCM 4 Less or Wait 4 Me
so were would i go to get pcm tuned like the place im getting the lift installed its like a offroading store/auto accessories.
I guess you missed it in the earlier posts, but try wait4meperformance or pcmforless. ;)
at http://www.pcmtuning.net
its $101.95 shiped for ur pcm to be dyno tuned 996-2000 Vortec S-10, Full Size Truck's, Van's, Suv's 4.3 , 5.7 , 7.4 SKU: A base performance tune can increase Horsepower, Torque, and in some cases an increase in MPG have been seen. We offer a base tune that has the potential to unlock a lot of power your vehicle has that the PCM will not let it use. The base tune is good for stock vehicles and vehicles that have bolt on performance parts. If you have a modified engine such as , forced induction, heads, cam, etc. we recommend that you bring the vehicle to us for a custom tune. This is the best way to get the best performance out of your certain combination. The list of some of the changes in the base tune that will help unleash your car or trucks power. Speed limiter removed Speedometer can be re calibrated for Tire/Gear change Fans will be set to come on at a lower temperature. Torque management will be removed Shift pressure can be increased ( If specified ) Remove skip shift 1-4 gear shift on a manual transmission RPM shift change ( If specified ) Change Fuel and Spark parameters Power Enrichment Delay is removed RPM Fuel cut off changed (VATS) Vehicle Anti Theft System removed ( If specified ) Trouble codes removed. egr, post cat oxygen sensors, etc. (off road use) |
you can use the k&n Cold air intake with a throttle body spacer but its not worth the 45 mins involved in popping the tb off.
| All times are GMT -5. The time now is 11:56 PM. |
