Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
best chip/cold air intake
Old May 25, 2009 | 09:03 PM
jdell1107's Avatar
jdell1107 is on a distinguished road
Default best chip/cold air intake
hey i was wondering what is the best chip/cold air intake for the 4.3 2000 blazer would be.
Old May 25, 2009 | 09:40 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
try running a search noth things have been discussed several times, but most true cold air intakes will give you the same results so whatever brand you go with is fine. as far as "chips" go i personally wouldnt waste money on one or any handheld youll get the most bang for your buck from a custom dyno tune or custom pcm tune, but like i said ealier just run a quick search do some research and decide whats gonna be best for you.
Old May 25, 2009 | 10:09 PM
mdehoogh's Avatar
I've been happy with my K&N FIPK intake. I also have a custom PCM tune from Wait4Me performance.
Old May 26, 2009 | 10:37 PM
001blazer's Avatar
001blazer is an unknown quantity at this point
I'm happy with the K&N too but, the only problem is that if you want to use a throttle body spacer you won't be able to use it with this brand.
Old May 27, 2009 | 01:21 AM
mikeinwi's Avatar
TB spacers are just noise makers are our engines anyway.
Old May 27, 2009 | 02:20 AM
Mission's Avatar
Mission is an unknown quantity at this point
I believe you can use the Air Aid Intake with their spacer. For a programmer Hyper Techs are nice but the best would be a tune with PCM 4 Less or Wait 4 Me
Old May 27, 2009 | 10:12 AM
jdell1107's Avatar
so were would i go to get pcm tuned like the place im getting the lift installed its like a offroading store/auto accessories.
Old May 27, 2009 | 11:18 AM
rriddle3's Avatar
I guess you missed it in the earlier posts, but try wait4meperformance or pcmforless.
Old Sep 14, 2009 | 11:46 PM
RebelJimmy96's Avatar
RebelJimmy96 is on a distinguished road
at http://www.pcmtuning.net
its $101.95 shiped for ur pcm to be dyno tuned
996-2000 Vortec S-10, Full Size Truck's, Van's, Suv's 4.3 , 5.7 , 7.4
SKU:
A base performance tune can increase Horsepower, Torque, and in some cases an increase in MPG have been seen. We offer a base tune that has the potential to unlock a lot of power your vehicle has that the PCM will not let it use. The base tune is good for stock vehicles and vehicles that have bolt on performance parts. If you have a modified engine such as , forced induction, heads, cam, etc. we recommend that you bring the vehicle to us for a custom tune. This is the best way to get the best performance out of your certain combination.
The list of some of the changes in the base tune that will help unleash your car or trucks power.
Speed limiter removed
Speedometer can be re calibrated for Tire/Gear change
Fans will be set to come on at a lower temperature.
Torque management will be removed
Shift pressure can be increased ( If specified )
Remove skip shift 1-4 gear shift on a manual transmission
RPM shift change ( If specified )
Change Fuel and Spark parameters
Power Enrichment Delay is removed
RPM Fuel cut off changed
(VATS) Vehicle Anti Theft System removed ( If specified )
Trouble codes removed. egr, post cat oxygen sensors, etc. (off road use)
Old Oct 22, 2009 | 01:34 AM
Rebels01blazer's Avatar
Rebels01blazer is on a distinguished road
you can use the k&n Cold air intake with a throttle body spacer but its not worth the 45 mins involved in popping the tb off.
