-   Performance & Brainstorming (https://blazerforum.com/forum/performance-brainstorming-38/)
-   -   Electric fan upgrade worth the time? (https://blazerforum.com/forum/performance-brainstorming-38/electric-fan-upgrade-worth-time-90414/)
Ricco Aug 8, 2015 10:07 PM
Hello everyone! I'm been thinking about replacing my factory fan for an electric fan, I did it once before on my brothers Cherokee and it got really quite and had less wasted gas and a tiny bit more noticeable power as the fan isn't holding the engine and creating power restriction, yes there's a few modifications that needed to be done but it worked. Has anyone here done this? Any advise or results to share?
newguy Aug 10, 2015 06:39 AM
Ihave and was very happy with the results. Same you stated above
Ricco Aug 10, 2015 08:40 AM
Thanks for replying,
Did you ran into any trouble or needed special modifications else than relays and coolant sensor?
blazen_red_4x4 Mar 7, 2016 05:49 PM
3 Attachment(s)
Living in hot Florida, it was one of the first things I did to my 04 when I got it. Intrepid/Sebring/Concord fans are easy to fit in. Hardest part is the wiring to be honest, and even that's not too difficult. Low speed on these fans is enough to keep the engine temp right at thermoset temp while idling on the hottest summer days with the AC on full blast :)
https://blazerforum.com/forum/attach...ine=1457394594
TMM217 Mar 7, 2016 06:39 PM
Its on my bucket list to do.
LeWhite Mar 8, 2016 11:26 PM
Did you ever wonder where the electric fans get THEIR power from?
El_Beautor Mar 10, 2016 09:51 AM
If only vehicles had an existing electrical system that would support an e-fan without needing any additional upgrades...
Automotive alternators do not control their electrical output by varying their mechanical load on the drivetrain. The mechanical load of the alternator on the drivetrain stay the same regardless of the power requirements of the vehicle, and the stock alternator is already making enough power to run an e-fan as long as you haven't added other power hungry systems like a big stereo.
newguy Mar 10, 2016 06:05 PM
I believe someone here did it with an adapter between the temp sensor and the block
Thogert Mar 10, 2016 08:05 PM
Can I ask where you get this info from? Because every generator I've ever seen or used, will need more power input to increase the output. Unless the alt is running at 100% of the time already, adding a larger electrical load will require more force to turn the armature than before.
I'll admit the power draw curve from the stock fan to electric fans will be different, you will still need to produce the power somewhere.
newguy Mar 11, 2016 05:15 AM
Agree with Above post, but a scrap yard d244 although and a new longer belt is fairly cheap.
