Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Fuel Pressure Gauge - Is this safe?
Old Jan 15, 2010 | 05:14 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default Fuel Pressure Gauge - Is this safe?
So due to my recent problems I've decided to install a fuel pressure guage. I created the hose as pictured below. It consists of a -4an hose end, a 1ft section of Fuel Injection hose, a brass 1/4 npt barb,a 1/4 to 1/8 npt female to female reducer, and finaly a 100 psi oil pressure sender(im using an oil pressure setup cause im a cheap bastard and i was told it is the same as a fuel pressure gauge.).
now the plan is to remove the shrader from the fuel rail and permanently install this hose and then zip tie the sender under the hood about 8 inces to the left of the wiper motor.
My question is; IS THIS SAFE?
Obviosly it makes me nervous, so please either reasure me itll all be ok, or tell me im a crazy idiot! Thanks!
EDIT: I can't believe nobody has ANYTHING to say about this?
Old Jan 17, 2010 | 05:55 PM
Seems to be safe! truck hasnt exploded yet ( knock on wood ). Ill get pics of the install when there is better light.
Ok, soo... what makes the pump spool up when you turn the ignition to on? seems it doesnt do it every time. ALSO just wiped the codes again and had the good ol p1406 thats allways chillin and a new p0446!
Help!
Old Jan 17, 2010 | 07:01 PM
I haven't responded because I can't tell what you used in the picture... Was hoping for some better pics... Regardless, I wouldn't leave it installed all of the time.
Don't you have another thread on your codes... If so, please keep the discussion there.
Old Jan 17, 2010 | 07:27 PM
[QUOTE=swartlkk;287975]I haven't responded because I can't tell what you use
Old Jul 7, 2011 | 06:50 PM
Just noticed that the last post got chewed up or something... anyways to the point.
I have had the gauge on the fuel schrader port, minus the schrader port innerds, for over a year now with no know ill effects.
bigdaddykane93
Oct 23, 2012 11:26 AM
sh1520
Nov 27, 2009 03:30 PM
Inferno
May 5, 2007 08:03 PM
scottyk
Apr 6, 2007 08:52 AM
XBlazer01
Sep 12, 2006 12:29 PM
