helping my blazer live longer
this is my first vehicle and i want it to live as long as i can
heres the things i hvae done to it so far K&N Air filter put it Valve head gaskets replaced Heater core replaced Oil changed next thing i want to do is get a throttle body spacer but where do i go after that to just try and help it live longer, increase performance, and maybe help out with MPG |
RE: helping my blazer live longer
The best thing that you can do to ensure a long life in your truck is to keep up with all the maintainence.
Change all the fluids regularly, treat the rubber weatherstrips, clean all the mud and salt of the bottom every spring etc... |
it has 170k miles on it
would it be worth it to get a cold air intake? |
your car sounds exactly like mine and this is exactly what i'm trying to do with my blazer (minus the HP increasing). i spent only $500but mine is a242,xxx mi. vehicle lol, butstill runs strong! to increase longevity, you can seafoam the motor to flush out everything (top end, injectors, TB, oil system). then, dump some Engine Restore in the oil to restore compression. after that, switch to synthetic to keep it running strong. make sure all fluids are properly changed at all times, and this will maximize performance, MPG and the overall life of the vehicle!
wow thats alot of miles for it to be running that well, do you have AIM id like to talk to you more about the procedure
i rarely use AIM anymore, due to college/work life. i can redirect you to a link from another forum i'm with, that explains the entire procedure. just let me know.
Or you could search here as seafoam has been discussed in numerous topics...
It will treat you how you treat it. Maintenance, maintenance, maintenance!
yea that link would be great and ill search around here as well
alright so i think this is what im going to do
put 1/3 of the can in the gas tank 1/3 in the engine 1/3 in the brake booster let sit for 10 minutes then rev it up, drive it around for a while till all the smoke clears, change the oil and then its done is this the right way?? |
| All times are GMT -5. The time now is 07:30 PM. |
