Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
onboard air 4.3L
Old Nov 5, 2010 | 07:58 PM
69chevelle's Avatar
69chevelle is on a distinguished road
Default onboard air 4.3L
I'm looking to put an edc in my truck, anyone done one while maintaining factory ac? Would love to see pictures as well as any tips you may have. I would prefer a york 210, or 209 but I think due to clearance reasons I might have to use a sandan or try and find a super compact york...
I have a 3" body lift so I don't know if I can clear the york compressor beside my alternator like most people due.. if you have this style, would it be possible to check for clearance? I am aware the overflow must go and computer mount would have to be made..
I already have a 5 gallon tank which I can mount under the body between the frame and driveshaft, have already checked for clearance and will fit great. Also have an airhorn, now I just need air I don't want electric!! or I would not be posting this. Electric compressors are easy to install but don't put out enough air to run air tools.
I drive a 2001 GMC Jimmy 4.3L 4x4, 3" body lift... so 4.3 vortec
Old Nov 7, 2010 | 02:59 PM
69chevelle's Avatar
no one is running an engine driven compressor as well as retaining factory a/c?
Old Nov 7, 2010 | 04:11 PM
I can't say as I have ever seen an s-series on here with an engine driven compressor.
Old Nov 7, 2010 | 09:11 PM
69chevelle's Avatar
well that's no fun. All the bagged guys running them don't seem to have a body lift *shrugs* guess I'm on my own. Got a few other things to take care off first, but I will make sure to keep everyone updated... That is If I can figure a way to mount it without removing my a/c and too much modifications... Otherwise I might be stuck with an electric.
Old Nov 8, 2010 | 02:58 AM
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
I'm just trying to do that too.
I think I'll go to the scrapyard on friday and look for a ac compressor. I think I'll go with a sanden...
Old Nov 8, 2010 | 12:52 PM
abig84's Avatar
My 93 has the ac compressor converted to a air pump and my front bumper is a tank but the ac don't work anymore. I gutted all that stuff a while ago. I've had that set up for a few years and really havenet neeeded it on the trail
Old Nov 8, 2010 | 02:22 PM
Could you please post some pics of that?
Old Nov 8, 2010 | 08:20 PM
69chevelle's Avatar
buddy of mine owns a scrap buisness, so basically I will be using whatever I get first
make sure you put an inline oiler to oil the sandan, or at minimum squirt some oil in it fairly often.
Sandan's are much easier to find room for and pump very similar air. but don't have much for internal oiling like the york's do
Old Nov 9, 2010 | 07:30 PM
abig84's Avatar
eh. theres really nothing to post a pic up of but ill see what i got. basically i did it the cheap and easy way. i got the a/c pump on a toggle switch, cut the lines and spliced into the output line and have that running to the bumper which acts as a tank. only reason i did was for emergency reason, like a flat tire on the trails. i really dont plan on running a impact. as far as oil, a little spray in the intake hose works fine
and theres the intake hose with the toggle to switch it on
Old Nov 10, 2010 | 02:33 AM
Thanks, that helped a lot...
Let's see what I get on friday...
