Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
roller rockers?
Old Feb 3, 2009 | 03:02 AM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
Default roller rockers?
okay so im looking for every little bit of power i can get out of my 4.3. I have read bout roller rockers and read that 2000+ have roller rocker while pre 2000 have stamper steel. What i was wondering was what ratio are the stock and what ratio could i substitute without changing anything else. it was suggested to use 1.6? what do you guys thinks? worth the 150.00$? I would like a cam but dont really wanna pull apart my new motor (which i just payed off). If i under stand right a bigger ratio would allow my truck to breathe more?? something like a cam? Please correct me if im wrong, just wondering how to add a few more ponies
Old Feb 5, 2009 | 01:11 AM
97ssblazer's Avatar
Default RE: roller rockers?
no input
Old Feb 5, 2009 | 07:14 AM
Been covered... CLICK HERE - just read the linked to reply in that thread. No need to get all caught up in the drivel that was ivannj.
I would not try to go with the stock 2000+ roller rockers as they were a roller trunnion only. Stock ratio is 1.5. Going to 1.6 will gain some lift, but not duration. Duration or area under the curve is where you really gain. With higher ratio rockers, you may end up with valve float, but unless you have raised your shift points and/or modified the max engine RPM, should be ok in that regard.
A cam would be a much better choice, IMO.
Old Feb 5, 2009 | 02:51 PM
97ssblazer's Avatar
yea a cam REALLY would be better but thats a lot of work. i was looking for simple "bolt ons" for now. Im moving to AZ soon and once i get out of MI below zero weather than its on.
Old Feb 5, 2009 | 03:35 PM
oisinirish's Avatar
Just out of curiosity...and this may be due to the difference in engines, I have a 305 4bbl, but why the preoccupation with hp when, as I understand it low to mid-range torque would increase performance in a more noticeable way?
Old Feb 5, 2009 | 04:42 PM
Different strokes for different folks...
Old Feb 7, 2009 | 09:36 PM
97ssblazer's Avatar
i've owned the truck now for 4 years. and after replacing literally EVERYTHING lol, i would like a little more power. i know these V6's don't have much to offer but im gonna try to get it all. i just ordered a custom tuned PCM so well see what that does.
AlphaCrow
Mar 19, 2015 05:00 PM
stlarry
Apr 21, 2009 12:20 PM
madhatter256
Feb 20, 2009 09:56 AM
smdepew1976
Engine & Internal
Jan 7, 2007 12:01 PM
1996BZR
Engine & Internal
May 18, 2006 12:39 AM
