tbi vs carb
Both are reliable. The TBI can be more efficient for varying conditions while a carb may need tuning if you drastically change your elevation. It used to be that most people knew how to tune a carb better and easier than tuning TBI. With the tools available now, it is every bit as easy to tune a TBI motor for the same power as a carb'd motor.
As said, a TBI motor will be better with angles than a carb. You also will not have problems with hard accelleration on a TBI motor.
Well..on that note I will probably just sell the aluminum intake and pocket the cash...As i said it was free so it isnt like im losing money.. I am going to look in a top end kit from edelbrock then to squeeze a little power out of my motor.
Thanks for the input
I will take the intake to my local lordco and see if they can find me one. If i cant order it though them or through a shop in canada i most likely wont do it. This is because when i have to order alot of my parts from the U.S. i pay exchange and shipping and tax it is no longer worth it to do.
Well...i will look at the intake to check but that is interesting is there a company out there that makes an adapter? I am pretty handy with machining metal would i be able to make the adapter myself? I could do it at school or at my dads shop.
There quite a few adapters available for mounting TBI's onto a carb'd intake and they are quite easy to make. What I have done in the past is to take the appropriate gaskets for either end and then mark out the bolt pattern and profiles onto a chunk of aluminum, then widdled them out. It is quite easy and those newer manifolds do make a difference in the power band.
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
dcayers
Apr 12, 2009 01:51 PM
