33" on my zr2
Old Aug 10, 2011 | 06:12 PM
blue_zr2's Avatar
blue_zr2 is on a distinguished road
Default 33" on my zr2
well they said it coulnt be done without a 6" lift or alot of cutting
well i dont have a 6" lift and didnt cut a thing!
33x10.50r15 bfg A/T
99 zr2 blazer
front i removed the front part of the flare thats it
front has 2" rought country lift.. keys and control arms
rear has 3" add a leaf and not yet install the 2" rear shackels im still workign on getting the bolts out... thats why there rear side bumper trim are still off in the pix... its making it ezer to get to the bolts.. i got one side done free and working on the other side now.. so the rear shackels are not on yet this is why the rear is still sitting low!
btw no rubbing street driving or at full turn
i still need to install the rear shackels and when the 2" P/A body lift gets here i will install that next weekend...
what you think?
i need more lift i should have ordered a 3" body lift and made my own bumper brackets...
Old Aug 10, 2011 | 06:59 PM
warthogdriver's Avatar
i think it looks great....
i would be nervous with the front tires..it looks mighty tight. i think a big bump and you will get a rub or two. the body lift will help ya out there.
like i said...otherwise looks awesome, great work.
Old Aug 10, 2011 | 07:14 PM
cbr995's Avatar
Looks great! I thought for sure you'd be rubbing at the front on the lower valance but if you're not...
Sigh... It's times like these I wish I bought a ZR2...
Old Aug 10, 2011 | 07:34 PM
blue_zr2's Avatar
ya hopefully the boty lift shows up soon... i have been soaking the body mount bolts and broke them all loose and ready to go..
this was i dont run into any problems.. and shouldnt take to long.. air and a good impact should take to long...
Old Aug 10, 2011 | 08:36 PM
xgiovannix12's Avatar
looks good
Old Aug 10, 2011 | 09:17 PM
Benedict1337's Avatar
you go the 10.5" wide which most 33's are 12.5 inches wide that may be one of the reasons you aren't rubbing. I bet if you go off roading in it it you'll rub. your stock wheels are helping too. looks like you're gonna need those add a leafs you got a little bit of saggin going on
Old Aug 10, 2011 | 10:00 PM
blue_zr2's Avatar
the tires i wanted 33x10.50 so i knew it would work on stock wheels without moding anything...
the add a leafs are in the shackels are not yet on yet....
plus adding the body lift this or next weekend
so i should be good...
Old Aug 10, 2011 | 10:14 PM
DKSDAD's Avatar
Looks real good. I do agree with Benedict, if and when you wheel it you may have some contact with the front valance. However you could always trim it down or remove it. Also, don't forget the ZR2 is already a bit higher then a standard Blazer.
Old Aug 10, 2011 | 11:26 PM
AJBert's Avatar
I can guarantee you will rub off road on the inner fender at partial to full flex with the wheels cut. Trimming is not that hard and you won't even notice it once you do it. Keep it on the street and you'll be fine. You "may" have to trim a bit on the rear of all four flares, more so on the rear flares, again for off roading.
This is after the BL, btw.
Old Aug 10, 2011 | 11:38 PM
blue_zr2's Avatar
i dont really go offroad this is a street daily driver..
maybe one day i will get it all ready and take it offroad but as it is now it stays to the streets and is a daily driver
