before and after pics body lift, add a leaf and t-bar crank with 31's
Old Sep 19, 2013 | 10:36 AM
95blazerlt's Avatar
95blazerlt is on a distinguished road
was thinking about making some shackles, and what exactly are ball joint spacers ? i just checked your build thread. wish i had a safari rack..
Old Sep 19, 2013 | 11:18 AM
newguy's Avatar
scroll down a bit and you`ll see em. Add an inch with out cranking the bars. Had to get wheel spacer though cuz the ball joint bolts on top rubbed the rim. https://blazerforum.com/forum/steeri...s-79195/page2/
Old Sep 19, 2013 | 04:59 PM
95blazerlt's Avatar
i checked those spacers out, we have an assortment of those at work for doing alignments however i thought they were only used to correct bad alignment angles.. Will have to try out a set and take some measurements. also wondering how thick of material did you build your shackles from and how far apart you spaced the holes?
Old Sep 19, 2013 | 05:53 PM
newguy's Avatar
I believe the shackles where 3/16ths and 2 inches more than stock . Every 2 inches more adds 1 inch of lift
Old Sep 19, 2013 | 05:54 PM
newguy's Avatar
also the ball joints where flipped from installed through the top to underneath the arm
Old Sep 21, 2013 | 10:44 PM
95blazerlt's Avatar
so even the lower ball joint gets the spacer ?
AGodlyCanuck
Lifting Tech
Apr 23, 2014 09:56 PM
TylerAustin22
Apr 29, 2013 12:44 PM
PaulO2288
Apr 21, 2011 12:25 AM
leeclark
Jul 17, 2009 03:59 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
