Blazer SS Pictures
Old Jun 16, 2006 | 05:11 PM
Blazer SS's Avatar
Blazer SS is an unknown quantity at this point
Default Blazer SS Pictures
http://s31.photobucket.com/albums/c3...action=options
This is a 98 Chevy Blazer LT, Supercharged, With too many engine updates to even think about, All rubber has been removed and polyurethane used, suspension updated for match to HP, I kept the 4x4, Very fast ! Track run and street driven.
Old Jun 16, 2006 | 05:36 PM
SniperX13's Avatar
SniperX13 is an unknown quantity at this point
Default RE: Blazer SS Pictures
Damn, Very, VERY nice looking Blazer.
What's your fastest 1/4mi ??
Old Jun 16, 2006 | 05:46 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
hawt!
Old Jun 16, 2006 | 08:14 PM
jagblazer01's Avatar
dude thats amazing....u got some #'s to go with it?
Old Jun 16, 2006 | 09:44 PM
Looks like you've done a bunch of nice work! What kind of boost are you putting through that plastic upper intake?
Does the crane fireball system give you some pretty decent control of the spark advance, does the computer complain about it and which model do you have? I have been thinking about getting a multiple spark discharge ignition system myself.
Old Jun 17, 2006 | 01:30 AM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
ORIGINAL: swartlkk
Go to the next page on that website. At first I was thinking, "what was he thinking just leaving that plastic upper intake on?!" So then I went to the next page. That is a sweet Blazer, that was put together the right way. That pic you looked at on the first page looked like a before-supercharger pic. On the next page you will see more pics of under the hood with the supercharger and all.
Old Jun 17, 2006 | 02:09 PM
Nope... I looked too and the plastic upper intake plenum (between the TB and the aluminum lower intake) is still there. You really can't push much boost without pushing out the factory MAP sensor which is just pressed in. Plus, I don't know how much boost a stock bottom end (with 9.5:1 compression) can handle either. Should still be fun to drive, but for the cost, a v8 conversion could be done.
And I hope that the air filter is isolated from engine heat because that compressor will add quite a bit of heat into the intake charge on its own. That could cause some serious knock that would be very bad.
Old Jun 17, 2006 | 04:12 PM
Blazer SS's Avatar
Where do I begin? I run 8-9 lb of boost, The stock intake manifold is holding up nicely for now. I have been searching for a aluminum manifold that accepts the current throttle body(I have a ported 78MM), problem is no one makes one! Plenty for a carb or tbi setup but none for our setup.
The truck is fun to drive ,but only on the highway, in any kind of a traffic jam or city driving, it SUCKS! The front lifts with the slightest touch of the pedal and it jumps from a full stop. The stopping distance of the brake system is phenomanal!! It will put you right through the windshield!! This is what you should think of if you go the performance route. Street drivability or all out performance. I chose all out.
I run SRP forged pistons, Eagle Hbeam rods, full rockers 1.6, Comp cams cam shaft, Fully worked polished and ported Vortec heads with 2.02 int and 1.6 exh, Beehive valve springs, JBA headers ceramic coated, High flow cat, JBA Evol 3" exhaust, Crane IS6 ignition, Crane retard mod, Twin fuel pumps (intank and inline), Vortech FMU, Accel 48000 volt coil, Accel 8.8 wires, There is a lot more !! I just have to remember. All lighting is L.E.D, Shocks are oil filled and nitrogen, And the Supercharger is a V2SQ Vortech, Stainless steel brake lines, Kevlar/Ceramic brake pads, Drilled and slotted rotors, Graniteli MAF sensor, Cold air intake (engine heat is blocked,draws air from the headlight area) ,Optima red top batt, All fluid is synthetic with the exception of water, this means all of the oil anywhere also.
Top speed restriction removed, BF Goodrich Z rated tires, 18" Eagle rims, one day I will get a total list of everything that is done to this Blazer, But that is what I can remember for now.
Old Jun 17, 2006 | 05:31 PM
No pictures with the engine apart?
Anyway, you may want to look into the marine application intake manifold for the 4.3L motor. Don't know exactly what else will be necessary, but it may be exactly what you are looking for. I can't seem to find them anymore, but I had found a few sites that had pictures of the marine application SCFI 4.3L motor with what looked like an aluminum upper intake plenum exactly like the plastic one on the automotive application engines.
Old Jun 19, 2006 | 10:50 AM
Blazer SS's Avatar
Thanks I'll check that out. I just added a few new pic's. I will find the pic's of the build up and the dyno runs, along with sound clips. Just have to find them.
