Calling All Lifted Trucks!
#481
2006 Trailblazer LS 4x4
Suspension Modifications:
Radflo Coilover's up front
SkyJacker CR25 Tahoe lift springs and Rough Country Nitro Shocks out back
suicidedoors.com Adjustable Panhard Bar
1/2 inch longer rear tubular control arms
Rear swaybar delete
Front swaybar quicker disco's
Exterior Modifications:
MarkMC 3 inch Body Lift
Cut fender wells
Cut Front Fenders
MDB Fab front and rear bumpers
Yakima Load Warrior w extention on Thule bars
20 inch LED lightbar and 32 inch LED lightbar
TrailGear Rock rails--THANKS BARTONMD for the install
Oil Pan Skidplate MDB
Radiator SkidplateMDB
Transfer Case Skid MDB
Engine Modifications:
Green Re-usable Air Filter
Gutted Air Box
Hooker Aero-chamber Muffler and aluminized piping w 3.5 in tip
PCMforless tune
Scanguage for monitoring
Interior Modifications:
Lights- LED
Stereo-Cd, subs
Cobra 75 WX CB
GM Custom Fit Black Leather Seat Covers
Husky liners
Divider Wall
Maglite n mount
Recovery Equipment:
12,500 lb winch with 7/16 Viking winchline
Bag of straps
emergency supplies, first aid, food, water
tools- Shovel, hatchet, large knife
hi-lift
shackles
Not recovery, but for safety there is always a firearm
Electrical Mods:
Just the lights mentioned above
Drivetrain Mods:
4.10 Gears
SS front diff
Rebuilt Disconnect + a spare with the sleeve
14 bolt rear diff
Lockright locker
Shortened rear steel driveshaft
1.5 Inch 6x5.5 Adaptors 14mm studs
Roller Mods:
35x12.50x17 Fierce Attitude MT
17x9 Black Rhino Spinreels
Matched full size spare
Rear swaybar delete
Cut fender wells
Cut Front Fenders
Gutted Air Box
PCMforless tune
Lights- LED
Stereo-Cd, subs
Cobra 75 WX CB
Husky liners
Divider Wall
Maglite n mount
Recovery Equipment:
Bag of straps
hi-lift
shackles
Electrical Mods:
Drivetrain Mods:
4.10 Gears
SS front diff
14 bolt rear diff
Lockright locker
Roller Mods:
#484
There is probably one or two pieces in the RC kit that are different, but the kit should still install. Is it a ZR2 kit?
The Trailmaster 5" kit isn't/wasn't that good anyway, the steering geometry was wrong, and it made for weird handling characteristics. $.02
#485
I re-called RC today and a new guy said that the crossmember does not match up on a 2dr and that people must be modifying their kits in some way. Does anyone have experience/ know what mods are necessary to make 6inch GM lift kit fit a 2dr 2001 Blazer LS?
#487
99 blazer lt1 corvette
99 4 door lt1 5.7 a/c all factory gauges abs cruze 6 inch lift 2 inch body just waiting on tires.
#489
my 93. doest really get much use anymore
basically just a set of k5 axles and transfer case attached to a all stock s10. has done amazingly well, biggest issue i keep having is every other year or so it likes to snap the steering box bolts while offroad. im thinking it has about 9 inches of lift
my mall cruiser, was built to be a offroad truck but turned out too nice i didnt want to destroy it
1986 k30, 4 inch lift and 33s
i got it for $300 as the previous owner stripped it off the axles and was going to scrap it. body was perfect when i got it, but 5 chicago winters claimed my cab corners. luckily winter hasnt been that bad up here and havent had to drive it the last two.
when i got it home from mississippi
#490
Post pics of your lifted truck and specs. This goes out to all those that are body lifted, suspension lift and lifted with shackles. This is a good thread so people who are thinking about lifting their trucks can see what it's going to look like.
My truck: 2001 Blazer LS
Suspension: 6" Superlift Kit with upgraded Bilstein Shocks, 2" PA Body Lift
Front & Rear Gears: Yukon 4.11's
Wheels: 20"x9" rims with 33" Mud Terrain Tires and 15"x8" (4.5" back space) pro comp series 97 wheels with 32" Pro Comp All Terrain Tires
Spacer: For rear wheels only, I have 1.25" billet adapters to even out the front and rear wheels.
Hypertech Power Programmer III: Have this to reprogram the computer and speedometer for the larger tires and gears.
Power Performance Upper & Lower Balljoints
Energy Suspension Body Mounts
^before the body lift^
With the body lift
Painted frame
With the body lift
Painted frame
how do you lift a truck? I would love my truck higher,with bigger off road tires...i have a 97 chevy blazer...
what kind of shop does this kind of work?
