Insane local blazer does 1000ft burnout
Old Nov 25, 2006 | 10:06 PM
Crashes's Avatar
Crashes is an unknown quantity at this point
Default Insane local blazer does 1000ft burnout
This was about a week ago, and he brought his slicks (good for 10.92's with slicks) but didnt bring the key so he decided to run at the track with his Street tires.
Keep in mind he has a 6.0l swap out of a silverado, and then he also turboed it.
http://s21.photobucket.com/albums/b2...rent=blake.flv
Old Nov 25, 2006 | 10:27 PM
Default RE: Insane local blazer does 1000ft burnout
Very cool! But... I think he needs a limited slip...
Old Nov 25, 2006 | 10:28 PM
Crashes's Avatar
He has one...bieleve me, its just the tires.
Old Nov 25, 2006 | 10:47 PM
The clip showing the tread marks doesn't make it look like he has a limited slip... At least not one that is working properly. You can see where he shifted and lit them both back up, but it sure looks like he's doin' a one-wheel-peel down the track...
Old Nov 25, 2006 | 10:48 PM
Crashes's Avatar
ORIGINAL: swartlkk
That would make sense except it is an auto
Old Nov 25, 2006 | 10:57 PM
Auto's can still spin through a shift. I should know, my Chevelle is an auto. The fact that it is an auto doesn't mean that the change from one gear to another would make it spin any more or less given the power that he is obviously putting down.
So it still makes sense. It was when it shifted and who's to say if he was manually shifting through the gears or just had it in OD.
*EDIT* - on the second run he definitely was spinning both tires, but on the first run is where it looked like only one was spinning judging from the marks left on the track.
Old Nov 25, 2006 | 11:09 PM
Crashes's Avatar
ORIGINAL: swartlkk
Im really just talking about the part when you said "and when he shifts"
Not the whole spinning thing or LSD.
Old Nov 25, 2006 | 11:20 PM
Ok so maybe I should have said when IT shifts instead, but even auto's can be manually shifted.
It's all besides the point. Great looking video! I'd be interested in learning more about the truck!
Old Nov 26, 2006 | 01:38 AM
jagblazer01's Avatar
awsome vid....that thing sounds pretty nasty
Old Nov 26, 2006 | 01:55 AM
Crashes's Avatar
Yeah, and the funny part is, its his daily driver. Stock bottom end and everything too.
