Picture Request: 2" Shackle Lift w/ 30" Tires
Old Mar 30, 2010 | 10:51 PM
Benedict1337's Avatar
looks like maybe 5 in backspacing? mine stick out a little more than that and they are 4.5 in. stock is 6 inch so that is prolly why you are rubbing. crank the tbars a little more and maybe get 1 in lift shackles and your truck would look pretty good with 30's
Old Mar 31, 2010 | 02:12 AM
kiwiblazer's Avatar
Originally Posted by leeclark
are you running stock rims or aftermarket rims? i have 31x10.50s on mine with just the shackle lift and t-bar crank, mine juts barely hits. i had to trim inner fender wells, but just barely touches the rear of the fender. only does it when i'm turning and the hitting a bump. my rims have 4" offset which makes the wheels stick out 1" past the fender, tends to make rubbing worse sticking out.
I've got the same problem. I've got the 3" or 4" backspacing (not sure anymore - need to check!) which pushes the wheels out flush with the flares. (My flares are wider than the US trucks). Had to lift the t-bar by 1" but now only occasionally catch the top of the fender. May need to lift another 1/2" in the front to solve this and then I'll definately need 2" shackles for the rear.
Old Mar 31, 2010 | 09:58 AM
Again, those claiming to have fit 31's, measure the outside diameter of your tire with a tape measure. I'm betting you will find that they may barely classify as 30's. Lesser brands tend to be undersized in the non-metric tire sizing scheme.
Old Mar 31, 2010 | 11:40 AM
99blaz's Avatar
99blaz is on a distinguished road
Swartlkk is right bfg a/t 31x10.50 for example are actually 30.7in, thats still pretty close but it will vary from manufacturer to manufacturer. Just keep that in mind when looking at tires and seeing what will fit.
Old Mar 31, 2010 | 12:16 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
My 2001 4x4, on 2 inch fabtec shackles. 30 BFG Mudders.
Old Mar 31, 2010 | 02:24 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
Very nice.
Old Apr 1, 2010 | 03:50 PM
foxxie's Avatar
So true & that's a reason why you don't mix different brands on 4x4s.
Old Dec 12, 2010 | 01:44 PM
wills-07's Avatar
wills-07 is on a distinguished road
Smile
does anyone know if i can run 30's on 4.5 backspacing rims if i do a t bar and shackle lift? any reply would help thanks! i plan on getting some pro comp black steelies so i dont have to run these ugly rims
Attached Thumbnails Picture Request: 2" Shackle Lift w/ 30" Tires-erererere.jpg
Old Dec 12, 2010 | 03:12 PM
djerock's Avatar
Banned
djerock is on a distinguished road
this is mine on a t-bar 1.5in crank and 30x10x15 rims with a 2wd off set.
Old Mar 3, 2013 | 12:04 AM
Matts Blazer's Avatar
Matts Blazer is on a distinguished road
Hmm, I can show you a 4d '97 sittin' on 28" w/ 2" shackle in the back?
Fronts a little bit bigger.
Yeah?
