Please rate my tweeter install.
Old May 8, 2011 | 08:18 PM
96jimmyslt4x4's Avatar
96jimmyslt4x4 is on a distinguished road
Default Please rate my tweeter install.
Got my first set of components.
I decided to mount the tweeter close to the woofer so it sounds like it's coming from one place.
How does it look?
Is there some gray paint I can get that won't clog the vents on the tweeter?
Old May 8, 2011 | 08:36 PM
warthogdriver's Avatar
i no stereo expert...but it looks like a good clean install to me.
as far as paint do several very light coats and you should be fine.
Old May 8, 2011 | 08:42 PM
You don't have to be an expert to notice a clean install. Means a lot to me, thanks!
Trying to keep it as stock as possible. so far this is now the only thing I can't un-do, but it's an upgrade. I don't see how anyone wouldn't want this...
Old May 8, 2011 | 09:03 PM
rodono's Avatar
rodono is on a distinguished road
looks good.
where did you put the cross over box?
Old May 8, 2011 | 09:21 PM
zedartwo's Avatar
Looks great. ^^please don't say in the door
Old May 8, 2011 | 09:34 PM
Heh.......
in the door...
There is a ton of room back there.
Where else should I put it?
Old May 8, 2011 | 09:54 PM
zedartwo's Avatar
Its not about room. They are very sensitive and not water tight. Any water gets down there and your crossovers are shot! I suggest either where the center console meets the firewall or somewhere else out of harms way of feet and water.
Old May 8, 2011 | 10:33 PM
I don't suppose a plastic bag would be of any help?
I was thinking about putting it somewhere behind the door panel if there is room.
Old May 8, 2011 | 11:08 PM
How's this?
Edit: this is the final outcome.
Perfect fit.
I even got the mids to fit perfectly in the door and don't stick out now.
Now I wonder if I can put those 3" full ranges..at least I think that's what they are called. I always see 6", 1" tweeters and then a 3" speaker.
Old May 9, 2011 | 07:37 PM
zedartwo's Avatar
I'm not a huge fan of where they are. I know its a PITA but try inside the cab. No water can TOUCH them let alone have a chance to ruin anything.
