01 Blazer front end
Old Nov 16, 2016 | 03:13 PM
HappyPappy's Avatar
HappyPappy is on a distinguished road
Question 01 Blazer front end
I have a 01, 2nd generation that I have to change the shiftier seal. Does it come out from the outside, or do I have to remove the axle housing and what would be involved with that?
Old Nov 16, 2016 | 05:47 PM
If it's leaking from where the actuator cable goes into the diff, there's no need for a major disassembly. Just remove the three bolts that hold the plate on that the cable is attached to and you can swing it out and make your repair, leaving the diff alone mounted under the truck. Heck, may be able to just unscrew the cable out, but without the cable being able to twist in the process since it's still attached to the actuator above, that may prove to be difficult...
If it's leaking between the axle tube and the diff housing however, some disassembly is required... Don't need to pull the housing out, but the axle tube will need to be pulled in order to seal it back up properly.
https://blazerforum.com/forum/steeri...ft-leak-57229/
Attached Thumbnails 01 Blazer front end-6486d1301445056-front-differential-shift-shaft-leak-sdc17794.jpg
Old Nov 17, 2016 | 01:09 PM
HappyPappy's Avatar
Thanks Mr Red, that's where it's leaking, at the fork. Had it off before and the shaft is real loose. It'll probably be easier the changing the oil filter lines, project #2 while it's up on stands
Old Nov 18, 2016 | 03:11 PM
HappyPappy's Avatar
Got the filter lines changed Had to jack up the motor so things would clear coming out. Wasn't as bad as I thought. Shiftier seal is another job, have to remove the tube for that. Question: What is going to fall out when I take the other two bolts out? The seal is pressed in from the inside
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
butters
Jul 13, 2008 06:39 AM
