remove the rear axle on 99 4wd blazer
I am trying to remove the rear axle on my 99 4wd blazer. I got the rear differential cover off and removed the pinion pin. I pushed the axle in and can see up in the pinion hole a clip on the end of it. I don't know how to get to it to remove it and then how to reinstall it. Please help.
Thanks
Thanks
If I remember right, you just rotate the axle till it falls into the diff. Its shaped like a letter "C".... Thats why you have to push the axle inward cause it cant come out when its in the slot...
Got it
I rotated the drive shaft along with the axle so the pinion hole stayed lined up and low and behold the little c clips dropped out. The axles slid right out.
Thanks for the help.
blajeans
01-09-2013 12:58 PM
jmaynard
07-12-2011 01:03 PM
cutthroatxxx
03-28-2011 09:07 PM
jorg
08-22-2010 03:47 PM
