1992 s15 GMC jimmy 4x4 problems
Old Nov 30, 2010 | 10:26 PM
GG_9_SE's Avatar
GG_9_SE is on a distinguished road
Default 1992 s15 GMC jimmy 4x4 problems
Sorry if this is in the wrong section, if so mods please move.
Ive searched alot on this, and i believe i have a small vacume issue, but thats not my real problem AFAIK.
When 4x4 does finaly engage after a couple trys. when i go down the road with it, it pulls on itself really bad, and sorta chugs as it goes down the road. After a couple miles or so it stops, and drives decent for awhile then it comes back. Im thinking possibly front drive shaft, or u-joints.
Let me know what you guys think, Thanks Kody.
Old Dec 1, 2010 | 07:11 AM
*Moving to Steering, Suspension, & Drivetrain*
Does it feel like the drivetrain is binding up? If so, have any of the axles ever been swapped? Maybe they didn't match up the gear ratios properly?
Old Dec 1, 2010 | 09:09 PM
GG_9_SE's Avatar
I had the drivers side cv replaced at time of purchase, but it did it on the test drive with the original one in also, or original afaik. how would i go about checking for correct gear ratio for the transfer case, and cv.
Old Dec 3, 2010 | 04:41 PM
GG_9_SE's Avatar
anyone?
Old Dec 3, 2010 | 06:33 PM
With all 4 wheels off the ground, vehicle supported on jack stands to the frame, mark a common spot on each tire (say 6 o'clock). Then engage the 4wd, put it in gear, and count the revolutions of the front and rear tires (making sure that all 4 tires are spinning). You should end up with the same number of revolutions both front and rear.
Another thing to check is that all 4 tires are the same size. If any one tire is off, it will cause the drivetrain to bind when in 4wd.
Old Dec 3, 2010 | 07:24 PM
GG_9_SE's Avatar
Alright thanks for the tip. So if the gear ratio is off how do I go about fixing this? I sound like such a noob to 4wd haha. I'm just more use to dodge's,mitsu's. just bought this jimmy as a winter beater so I could park my evo.
Old Dec 3, 2010 | 07:29 PM
You would have to get the gear set replaced to match. You could do this in either the front or the rear axle (rear is easier IMO). But check the tires first. That is a more plausible explanation.
Old Dec 4, 2010 | 02:50 PM
GG_9_SE's Avatar
Well I checked all my tires and the ******* that had it before me put 2 different size tires on the front. Passenger is a 205/70, and driver side is a 215/70. So I'm guessing this is where my hoping/ pulling going down the road problem is coming from.
Old Dec 4, 2010 | 02:51 PM
That could do it. It doesn't take much to cause bind.
Old Dec 16, 2010 | 02:00 AM
GG_9_SE's Avatar
well i got all new, and same size tires put on haha. 4x4 works like a dream now. thanks for the help everyone.
Advantage049
Feb 11, 2011 04:59 PM
89jimmy22
Aug 14, 2010 09:39 PM
1993gmcjimmyW
Jun 30, 2010 10:02 AM
eddiep23
Jun 18, 2010 11:11 PM
