1997 Bravda
no, the front axle is always engaged and doesn't have the actuator to lock and unlock it either. If you simply take out the front drive shaft you will damage the transfer case. You could either witch to a 2wd transmission or swap transfer cases with a 4x4 and keep it in 2wd, however you wont have the push buttons to change it into 4x4 or low, it could only be done manually with a wrench under the truck
polcat1998
03-01-2006 06:05 PM
drumzandrekkids
02-10-2006 11:24 PM
psawatsky
08-06-2005 01:48 AM
