1997 Jimmy Front Differential
Old Apr 2, 2013 | 11:23 AM
Wisco Blazer's Avatar
Wisco Blazer will become famous soon enough
Default 1997 Jimmy Front Differential
So I am having trouble getting the motor out of my 97' Jimmy, We have the bellhousing completely disconnected, torque converter bolts still connected (Seized in). We have the engine slid forward so the torque converter is disconnected from the tranny, but it still hits the bellhousing when we try to lift.
I need about 6-12 more inches of wiggle room forward because the oil pan is hitting on the front diff.
Can I remove the front diff itself without removing all the control arms and steering components?
If so, what is the procedure?
Thanks in advance.
Old Apr 2, 2013 | 03:17 PM
El_Beautor's Avatar
To remove the front diff you will need to pull the CV axles, but you may not have to pull the steering center link, although it's easier to drop the diff if you do. You'll probably have to remove the driver side upper control arm to get to the bolt for the upper diff mount. The access hole is behind the upper control arm.
Old Apr 2, 2013 | 03:56 PM
Thanks! Will look into it today. Air tools here i come haha
Old Apr 2, 2013 | 04:44 PM
okiedoak20's Avatar
yea the sterring center link removed makes it a lot easier, and it seems that the CV axles do need to be removed to remove the diff...
wow what a PITA
Drew4711
Oct 6, 2012 12:47 PM
remm jake
Apr 9, 2011 10:22 AM
PhilX
Oct 21, 2010 08:55 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
