1999 4x4 problem
Old Jan 6, 2010 | 06:14 PM
cook8106's Avatar
cook8106 is on a distinguished road
Default 1999 4x4 problem
Well bought a 99 blazer about a year ago. I used the 4 wheel drive once, worked great. This winter got a snow storm tried to use it and it didn't work. It is push button (4 button) has the auto 4x4. This is what happens I push 4hi and it blinks and says service 4 wheel drive but wont go. It will go in to 4lo, but still blinks and says service. When I push 4hi I do here a click in the tccm but nothing happens. I have pulled the battery out and looked at the vaccum actuator looks fine. I have checked the tccm it also looks ok. I pulled out the courtesy lamp fuse and the atc fuse left them out for a few mins replaced them turned the key on and off five times still nothing. Any ideas would be awesome Im lost. Please help thanks.
Last edited by cook8106; Jan 6, 2010 at 06:17 PM. Reason: needed to specify something
Old Jan 6, 2010 | 07:37 PM
The 'service 4wd' light is very much like the check engine light. When it turns on, the TCCM has stored a trouble code indicating the problem. You need to get the TCCM scanned to retrieve the trouble code. This can only be done by a scan tool capable of communicating with all of the serial devices in the truck (GM Tech2 or equivalent full feature scan tool) and is typically something that a shop must do (autozone, etc scanners are usually not capable of this). Get the code and let us know what it is. We'll go from there.
Old Jan 6, 2010 | 08:00 PM
cook8106's Avatar
Thanks I will get it scanned asap and let you know. Question though the service 4 wheel drive light only comes on when a button is pressed, so is it possible that it might just be a vaccum line is off or broken. I have noticed that some other hoses where looking kind of rough.
Old Jan 7, 2010 | 06:47 AM
You can look over the lines relatively easily. You will have a line that runs from the engine to the solenoid on the firewall and then one that runs from the solenoid to the actuator under the battery.
Old Jan 19, 2010 | 08:29 PM
cook8106's Avatar
I found a hose off. Here is a link to a photo that is identical to my issue could this be my problem, and if so where does it go/location? http://www.kylestubbins.com/files/images/IMAG0025.JPG
Old Jan 19, 2010 | 09:03 PM
Goes into the vacuum reservoir which is located inside the driver side fender right in that general area.
kamilkowalski
Apr 30, 2015 08:36 PM
BooTs
Mar 16, 2013 04:09 AM
Tinted
35
Feb 7, 2011 01:12 PM
ZLover4Life
Dec 5, 2010 10:28 PM
ZAKSKY
Dec 9, 2009 10:35 AM
