2 inch body lift?
Old May 3, 2009 | 01:05 AM
jimmy1996's Avatar
jimmy1996 is on a distinguished road
Question 2 inch body lift?
hey ive got a 96 jimmy and i wanna put a 2 inch body lift on it. will this screw up any linkage or anything?
Old May 3, 2009 | 01:09 AM
bandidolenny's Avatar
It will not cause any problems if installed correctly. A 2" body lift is definitely the way to go... after that you can also slightly crank up the torsion bars to lift the front and level it out.
Old May 3, 2009 | 01:15 AM
jimmy1996's Avatar
ok cool ya i already cranked my torsion bars and did a 1 1/2 inch shackl lift
Old May 3, 2009 | 01:22 AM
Then you will really be happy with the true 2" of lift from a body lift. You can also gain more lift with taller tires as well.
Old May 3, 2009 | 01:28 AM
jimmy1996's Avatar
ya im running un true 31s right now haha. what tires would u reccomend for it?
Old May 3, 2009 | 01:32 AM
jimmy1996's Avatar
is a body lift hard to put in on a jimmy? cause the only body lift i have ever done was on a 1980 shevy 2500 and thats about as simple a it gets haha
Old May 3, 2009 | 01:33 AM
31"s are as tall as you can get away with without rubbing at full lock while hitting a bump. I ran around on a set of borrowed 33"s for a few days and they banged the hell out of the rear of the front wheel wells.
In my opinion, a S-Blazer is easier than a body lift on a fullsixe pick-up. Less mounts to deal with.
Old May 3, 2009 | 01:37 AM
jimmy1996's Avatar
ok is it easy to get to all the mounts and bolts?
Old May 3, 2009 | 01:45 AM
Yes, once you get the bumpers off. Don't forget about the ones above the rear axle, alot of people overlook those and then can't figure out why the body won't separate from the frame. lol
It helps to read through the instructions a few times before starting any work. You may see or realize something that you otherwise wouldn't have thought of.
Old May 3, 2009 | 01:50 AM
jimmy1996's Avatar
ok man thanx
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
blazinUP
Tires and Wheels
May 14, 2010 08:06 PM
K5-Roots
Lifting Tech
Feb 6, 2010 12:09 PM
brino1
Dec 16, 2009 04:17 PM
