2000 Blazer 4x4 stuck in 4 LO
Old Aug 12, 2013 | 03:26 PM
larsnand's Avatar
larsnand is on a distinguished road
Default 2000 Blazer 4x4 stuck in 4 LO
I have a 2000 S-10 Blazer. The transfer case is stuck in 4LO. I have the 4-button push selector switch. When I try to press to go to 2WD or any other selection, that button blinks numerous times and stays in 4-LO. Nothing happens. I have it in neutral. Fuses are ok. I have good vacuum to the front differential diaphragm and it engages the front differential. I looked at/cleaned the TCCM pins and they seemed fine. Please help. I cannot figure it out.
Old Aug 12, 2013 | 05:13 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
Try getting it rolling 3 or 4 mph, shift into neutral, and then push 2hi. these trucks like to be rolling slightly to get in/out of 4lo.
Old Aug 19, 2013 | 02:35 PM
larsnand's Avatar
Thanks for the tip, but that did not work. I'm guessing it's the TCCM, motor, actuator or switch. What's the best diagnostic procedure to isolate the problem? Or, how can I manually switch it back into 2WD so I can atleast sell it?
Old Aug 19, 2013 | 06:06 PM
liljoejoe54's Avatar
liljoejoe54 is on a distinguished road
Check the actuator, I think it is under the battery. From what I hear, sometimes the rubber gets dry rotted and can cause the actuator to stop working correctly. You might need to replace it.
Old Aug 19, 2013 | 11:11 PM
Thogert's Avatar
If it's stuck in 4low, the actuator probably has nothing to do with the issue. The problem is most likely in the transfer case shift motor. You can try to remove it and shift it manually with a wrench to get it into 2hi.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
ryndraeger
Nov 21, 2009 05:15 PM
Scubasteve2365
Sep 11, 2006 12:29 AM
