2000 Blazer G80 not working properly, What could it be?
Old Jan 22, 2009 | 08:54 PM
JODYM's Avatar
JODYM is an unknown quantity at this point
Default 2000 Blazer G80 not working properly, What could it be?
I had the parts guy today run my serial# to find out my diff. size and gear ratio. He told me I have a 7.625" with 3:42 gears and a G80 Locker I just bought this blazer about a month ago and have plowed with it a few times in low range 4x4 and the rear differential does not act like a posi diff./ locker, I just have the traditional one wheel spin. The blazer has 152 000 km on it and i Know the previous owner and it's been babied all it's life and never been off-road and also know that it is possible that it's the original rear diff. fluid. I'm going to get a new diff. gasket tomorrow and change the rear diff. oil and look inside the differential but what should I look for or inspect while I have the diff. cover off. I will be installing Synthetic 75w90 gear oil. I plow with this vehicle now and need that extra wheel spinning, can anyone please help or have any suggestions Thanks Jody
Old Jan 22, 2009 | 09:35 PM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
Default RE: 2000 Blazer G80 not working properly, What could it be?
hey, i just did my diff service about 2 weeks ago. go to the diy part of the forum and look at the diff service post by swark. he has pictures and writes what he did. its pretty helpful. i was in the same boat as you. my truck had the same diff oil since it came from factory. i poped it opened and checked the mag. for any metal. i had alittle but that was about it. then look at the gears for ware. after i put everything back together, i went out with friends and was messing around in the parkinglot. wasn't expecting my diff to lock when i hit the gas. i was doin doughnuts. lol, good stuff.
Old Jan 23, 2009 | 06:51 AM
It is always possible that it no longer has the same rear end under it...
If it does, it is possible that the governor mechanism inside the diff has broken which is a common problem with the Gov-Loc diffs if abused.
Old Jan 23, 2009 | 03:11 PM
JODYM's Avatar
When you say the gov lock mechanism is there any pictures on here of what it looks like Thanks I know the vehicles history before i bought it and the rear diff was never touched it was a sunday driver to church and back home unless the G80 wasn't installed from factory it should be there as the serial# says it should will know more in the next few days again is there any pictures please help Thanks
Old Jan 23, 2009 | 05:06 PM
Pop the diff cover and have a look. If it looks like the picture below (one of the pictures in the Rear Axle Service DIY post), then it is a G80 and you likely have broken something internal to the diff.
austrochevy
Mar 18, 2014 01:02 PM
6gear
24
Mar 18, 2010 11:32 PM
my96willkillu
Feb 12, 2009 07:31 AM
JODYM
Jan 21, 2009 09:50 PM
DevizesChris
Oct 15, 2007 02:54 PM
